Caller ID
Discussion in '3CX Phone System - General' started by architechture, Dec 7, 2018 at 7:48 PM.
  1. architechture
    Apr 3, 2013
    8
    3CX gives multiple locations to input a Caller ID. Does this actually work on some providers? Vitelity allows you to set the CNAM/LIBD on each of its lines and that's what shows on the other end. (though I've had old CNAMs show on the other end for years after change when calling to certain areas or numbers.)
    When I fill in the Outbound Caller ID on a SIP trunk for use with Vitelity the call won't even go through let alone show on the other end.
    Thanks,
    11,095
    327
    You would have to confirm with the provider, if they allow a number change, and what field in the Invite they take it from. You can also put an outside number to be displayed in the extension settings. i have also seen a number, put in the phone settings, that in some cases, has taken precedent. There are outbound trunk settings that may need to be tweaked, to allow this to work.
  3. cobaltit
    cobaltit Well-Known Member
    Mar 22, 2012
    1,590
    239
    Sounds like you are trying to put a CNAM in the caller id fields which is a no-no. You push digits out which the receiving end will then check the CNAM database for whatever you registered with Vitelity.
    YiannisH_3CX likes this.
  4. 12494
    12494 Member
    Apr 16, 2010
    306
    31
    We use Vitelity and they respect the CID that the PBX sends. As other poster said - CNAM is not sent by 3CX.
  5. architechture
    Apr 3, 2013
    8
    You are correct. I goofed that up. Thank you.
