caller ID_not showing
Discussion in 'iOS' started by jits04, May 10, 2011.
  1. jits04
    May 2, 2007
    76
    I can't see the caller ID. I see my extension number when an call arrives.
    For example:
    100 - My extension number on Iphone
    101 - My Extension number on Grandtream Phone
    If I call from extension 101, I can't see the caller ID. If I call from external number I can't see the caller ID. Of course, I can see it on the others phone.
    Thank you an advance
    William
  2. StefanW
    Jun 2, 2009
    1,222
    93
    in a few installations this is been send, when the caller ID from the gateway is not been send in the From Display Name.
    A change will may make it to version 1.0.24
