Caller is not resolved or forbidden
Discussion in '3CX Phone System - General' started by Anonymous, Sep 21, 2006.
  1. Anonymous
    Anonymous Guest
    When I try to call an extention (local to local), I get the following error:
    Caller is not resolved or forbidden, sent 403 response
    18:21:52.867 CallConf::saveCallEvent Incoming c11 "101"<sip:101@192.168.0.12> "0102"<sip:0102@192.168.0.12> Incoming call (before routing)
    18:21:52.877 CallConf::saveCallEvent Rejected c11 "101"<sip:101@192.168.0.12> "0102"<sip:0102@192.168.0.12> Caller is not resolved or forbidden, sent 403 response
    18:21:52.877 CallConf::saveCallEvent Terminated c11 "101"<sip:101@192.168.0.12> "0102"<sip:0102@192.168.0.12> Call ended
    Both caller and callee are register and their status is "on hook".
    Any help will be greatly appreciated.
  2. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,994
    304
    Firewall
    Do you have a firewall running on the machine? If yes can you disable it and try again?
    Can you call the other phone directly using its IP, i.e bypassing 3Cx Phone SYstem completely?
  3. Anonymous
    Anonymous Guest
    Firewalls are disabled on both PCs.
    I haven't tried bypassing 3cx as I don't know how to place call directly.
  4. 3CXsupport
    3CXsupport New Member
    Aug 21, 2006
    193
    You seem to be calling 0102. Use the 0 prefix to place external calls only. I think you should be dialing 102. Can you please check if this solves you problem?
  5. Anonymous
    Anonymous Guest
    I am not dialing 0. I am only dialing 101 or 102.
  6. 3CXsupport
    Aug 21, 2006
    193
    Thanks for the feedback. If you really dialled 102, I do not see any other explanation why the system logged ""0102"<sip:0102@192.168.0.12>" other than that your phone (or soft phone) is adding the 0. I beleive so because the first line of the log "(before routing)" is the request exactly how the 3CX PhoneSystem received the call (no alterations).
    Can you let us know which client you are using?, or maybe please try to place a call with our softphone first. It is a very light and straigh forward tool. http://www.3cx.com/voip/voip-phone/ . If you need a walk through the manual has a clear guide under the "configuring a software based SIP phone" section.
    You can also check in the "Line Status" page to see if your phone is properly registered using the right username and password.
