Caller Name = MakeCall **FIXED IN RC2
Discussion in '3CX Phone System - General' started by beaton, Apr 28, 2011.
  1. beaton
    Jan 4, 2011
    11
    Using V10 RC and 3CX Softphone V6 with 3CX MyPhone installed locally with desktop components.
    When dialing a phone number directly from the 3CX Phone my call recording correctly show Call Info:
    [BEaton]_1015-95555555555_20110428142546(8).wav
    When I dial the same number using 3CX MyPhone the call recordings use the alias MakeCall:
    [MakeCall]_MakeCall-1015_20110428142606(9).wav
    The 3CX Phone also displays "MakeCall" for the caller information...I had the same results when using CounterPaths's Bria softphone.
    Is this the desired behavior?
  2. marcin.brogul
    Jun 27, 2011
    I have this same question. It is possible to change name MakeCall on number outgoing call?
