caller name not displayed for inbound external calls
Discussion in 'Windows' started by Veerendra, Dec 14, 2016.
  1. Veerendra
    Dec 14, 2016
    Recently we have set up the 3cx v 15 version PBX system. Every this was working fine. But we are unable to get displayed the caller name when we get the call from external (Apart from our extensions) to our extensions.
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,783
    563
    If the name is your company phonebook you can change the options from the contacts tab in the management console.
    If not and your provider sends a caller ID then you need to know in which SIP field this information is sent so you can adjust your inbound parameters accordingly in the trunk settings
  3. leejor
    11,286
    360
    Was this working previously? Did you check the 3CX Activity log to see if the name is being sent? What type of trunking are you using?
