Solved Caller Name not displayed...sometimes
Discussion in '3CX Phone System - General' started by narkumas, Jan 18, 2018.
  1. narkumas
    narkumas New Member
    Nov 28, 2016
    227
    23
    Hey!
    I have a very strange behavior on Webclient with external calls (mobile phone in this example)
    In the picture you see user DM (Dirk Möller) who is displayed with his initials DM in the circle AND with his full name.
    user MN is also known and You see his initials in the circle too. But the whole name is not displayed.
    ??? Uhhh ??? What's wrong?
    I am using the most recent version of 3cx
    Also while signaling the name is neither displayed on the deskphone nor on the client app.
    I can see no rule...
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,061
    56
    If I understand correctly, on some calls the CID is seen and shows up in the 3CX apps, but in others it does not. Correct?
    If so, you will likely need to do some captures to try and identify the issue. Given that 3CX is able to see some, it implies that it is working if and when the various calls coming to the system meet the criteria by which CID is to be detected and if and when the delivering carrier is sending CID.
  3. narkumas
    narkumas New Member
    Nov 28, 2016
    227
    23
    no. The callers are identified correctly by 3CX as You can see in the purple circles:
    The initials MN indicate that the caller is me: Marius Narkus
    DM indicates that the caller is Dirk Möller
    We both are users (extensions) in 3CX and do both have mobile number entered.
    This looks like a bug to me...
  4. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,392
    279
    Is the contact a personal or a system wide contact? Also do you have a first name last name configured in the contact or is the under company name etc?
  5. narkumas
    narkumas New Member
    Nov 28, 2016
    227
    23
    Oh, I just noticed:
    contact MN is an extension:
    contact DM is a system wide contact:
  6. YiannisH_3CX
    May 10, 2016
    4,392
    279
    I believe i understand the issue
    You are calling from a number that is set as mobile number of an extension that belongs to the system but it is not added as a contact and not directly from an extension.
    Let me try to replicate the issue and i will get back to you with an update.
  7. narkumas
    narkumas New Member
    Nov 28, 2016
    227
    23
    Hey Yiannis,
    I have discovered that there was someting wrong with my contacts. Those which have been synced by ODBC were not okay. I tried to edit one manually and it gave an error message.
    Then I removed all those contacts. After a resync it worked again.
    *solved*
    br
    Marius
  8. YiannisH_3CX
    May 10, 2016
    4,392
    279
    Glad to hear the issue is now resolved. Thank you for sharing your solution
