caller Number format
Discussion in '3CX Phone System - General' started by GMR2000, Jun 23, 2014.
  1. GMR2000
    Jun 23, 2014
    I have implemented SIP trunk between two systems - 3CX and another PABX (B) in my LAB
    I was able to make calls between two systems and can see caller ID as extension number coming from 3CX.
    But i need to show Prefix and extension number both on PABX B's extension
    Eg: extension 101 and Prefix 73 on 3CX and dialing PABX B.
    So PABX B's extension should shows 73101. Currently it shows only 101.
    Is it possible on 3CX?
    10,375
    231
    There is the ability to add prefixes on calls coming in on "regular" trunk groups to allow the number to be re-dialled. I'm not sure if the same options are available for bridged trunks. In the extension options you can specify the extension number to be shown. I know that if it is left blank (the default) then the "regular" number will show. Changing this, however, will probably affect all number displays, internal and over the bridge.
