Caller number is a string instead of a number
Discussion in 'Windows' started by netengine, Nov 23, 2016.
  1. netengine
    Nov 23, 2016
    Hello team,
    since 3-4 weeks we get sometimes calls where we here nohting (nobody on the other side of the line).
    The caller number is always a string:
    [CM503001]: Call(C:291): Incoming call from Line:10000<<test to <sip:80@192.168.0.242:5060>
    [CM503001]: Call(C:291): Incoming call from Line:10000<<a'or'3=3-- <sip:80@192.168.0.242:5060>
    The string is always diferent but often it has the "(something) 'or' (something) = (something)".
    Does anyone know what these is? What can i do to prevent it?
    Sorry for my bad english (i didnt know how to do a thread at the german forum).
    Regards!
  2. agp
    agp 3CX Team
    Aug 19, 2015
    134
    19
    This looks like a common SQL Injection attack.
  3. netengine
    Nov 23, 2016
    @agp Thanks for the answer. How can i prevent this?
  4. leejor
    10,362
    227
    Does this actually come in on a trunk from a provider, or is it a direct SIP call? If it is a direct SIP call, and you have to have that option (allow direct SIP calls) enabled, in 3CX, for other call types then there would be an originating IP that could be blacklisted. If the call comes in on a trunk from a provider, you might want to talk to them about the possibility of blocking (or tracing) numbers without a proper numeric CID.
    Are they always calling the same extension? If so, and you can stop them any other way, you may have to eliminate that extension depending on how annoying the problem becomes.
