CallerID changing
Discussion in '3CX Phone System - General' started by izaxon, Aug 1, 2010.
  1. izaxon
    Aug 1, 2010
    I have the following setup:
    POTS => SPA-3102 => 3CX => PAP2T => phones
    When I get a call it is routed from POTS to the phones. First I see the correct caller ID (external number) and then it changes to 10001 which is the virtual extension number for the SPA-3102 connection.
    I just want to see the correct caller ID number and not the virt. ext. no. on the phones. Does anyone know how to change the settings to get it to work?
    Cheers,
    Johan
    11,277
    360
    Caller ID (analogue) is sent in one "burst", name and number fields. Could it be that the call display device is only capable of displaying one field at a time (cycling) and the outside number and the 10001 are, in fact, both being sent? Is the PAT2t set for North American type CID? Have you tried a display capable of showing both name and number fields at the same time?
  3. izaxon
    Aug 1, 2010
    It seems like first the correct number is sent, then also 10001 is sent.
    On the phone I can see two phone numbers on the caller list, both at with the same timestamp.
    How do I change the PAP2T caller id type? (I run 3CX in Sweden, Europe.)
    Thanks,
    Johan
  4. leejor
    11,277
    360
    In the Regional Tab, you should see Caller ID Method. There should be a setting for Finland & Sweden, I guess you two countries use the same DTMF CID method.
  5. izaxon
    Aug 1, 2010
    Thanks,
    The CallerID Method was already set to Finland & Sweden. So, what else could be wrong? Why is the caller ID info for the extension (10001 in my case) sent after the real (first burst?) phone number?
    Log of an incoming call:
    11:16:41.527 [CM503008]: Call(188): Call is terminated
    11:16:37.658 [CM503007]: Call(188): Device joined: sip:10@192.168.0.110:5060
    11:16:37.643 [CM503007]: Call(188): Device joined: sip:10001@192.168.0.129:5062
    11:16:37.627 [CM505001]: Ext.10: Device info: Device Identified: [Man: Linksys;Mod: SPA Series;Rev: General] Capabilities:[reinvite, no-replaces, able-no-sdp, recvonly] UserAgent: [Linksys/PAP2T-5.1.6(LS)] PBX contact: [sip:10@192.168.0.116:5060]
    11:16:37.627 [CM503002]: Call(188): Alerting sip:10@192.168.0.110:5060
    11:16:34.819 [CM503025]: Call(188): Calling Ext:Ext.10@[Dev:sip:10@192.168.0.110:5060]
    11:16:34.788 [CM503004]: Call(188): Route 1: Ext:Ext.10@[Dev:sip:10@192.168.0.110:5060]
    11:16:34.788 [CM503010]: Making route(s) to <sip:10@192.168.0.116:5060>
    11:16:34.788 [CM505002]: Gateway:[PSTN] Device info: Device Identified: [Man: Linksys;Mod: SPA Series;Rev: General] Capabilities:[reinvite, no-replaces, able-no-sdp, recvonly] UserAgent: [Linksys/SPA3102-5.1.10(GW)] PBX contact: [sip:10001@192.168.0.116:5060]
    11:16:34.757 [CM503001]: Call(188): Incoming call from 10001@(Ln.10001@PSTN) to <sip:10@192.168.0.116:5060>
    11:16:34.757 [CM503012]: Inbound out-of-office hours rule (unnamed) for 10001 forwards to DN:10
    11:16:34.538 [CM503008]: Call(187): Call is terminated
    11:16:28.891 [CM503025]: Call(187): Calling Ext:Ext.10@[Dev:sip:10@192.168.0.110:5060]
    11:16:28.860 [CM503004]: Call(187): Route 1: Ext:Ext.10@[Dev:sip:10@192.168.0.110:5060]
    11:16:28.860 [CM503010]: Making route(s) to <sip:10@192.168.0.116:5060>
    11:16:28.860 [CM505002]: Gateway:[PSTN] Device info: Device Identified: [Man: Linksys;Mod: SPA Series;Rev: General] Capabilities:[reinvite, no-replaces, able-no-sdp, recvonly] UserAgent: [Linksys/SPA3102-5.1.10(GW)] PBX contact: [sip:10001@192.168.0.116:5060]
    11:16:28.844 [CM503001]: Call(187): Incoming call from 10001@(Ln.10001@PSTN) to <sip:10@192.168.0.116:5060>
    11:16:28.829 [CM503012]: Inbound out-of-office hours rule (unnamed) for 10001 forwards to DN:10
    11:16:28.532 [CM503008]: Call(186): Call is terminated
    11:16:22.932 [CM503025]: Call(186): Calling Ext:Ext.10@[Dev:sip:10@192.168.0.110:5060]
    11:16:22.916 [CM503004]: Call(186): Route 1: Ext:Ext.10@[Dev:sip:10@192.168.0.110:5060]
    11:16:22.916 [CM503010]: Making route(s) to <sip:10@192.168.0.116:5060>
    11:16:22.916 [CM505002]: Gateway:[PSTN] Device info: Device Identified: [Man: Linksys;Mod: SPA Series;Rev: General] Capabilities:[reinvite, no-replaces, able-no-sdp, recvonly] UserAgent: [Linksys/SPA3102-5.1.10(GW)] PBX contact: [sip:10001@192.168.0.116:5060]
    11:16:22.901 [CM503001]: Call(186): Incoming call from 0702358310@(Ln.10001@PSTN) to <sip:10@192.168.0.116:5060>
    11:16:22.870 [CM503012]: Inbound out-of-office hours rule (unnamed) for 10001 forwards to DN:10
    Thanks,
    Johan
  6. leejor
    11,277
    360
    Unfortunately I'm not familiar with CID methods outside of the Bellcore type used in North America. Perhaps the system used in Finland allows for additional information to be sent later. I would start doing a search specific to the CID used in your country. It could be a setting but it may also just be the 3CX is handling it. If your CID devices are number only, then they may have a problem handling more than one number sent to them. That may also be the case with other DTMF bases CID systems, so you may be in a similar situation to countries other than Finland and Sweden. A quick search came up with something like this. http://forum.voxilla.com/cisco-linksys-sipura-voip-support-forum/problem-dtmf-caller-id-17687.html
    You may find something more relevant to your particular problem searching the Finnish or Swedish version of Google or another search engine.
  7. izaxon
    Aug 1, 2010
    I followed the link and made the suggested change to PSTN Ring Timeout value (from 5 to 6 seconds) in the SPA-3102 unit. That solved it. Now Caller ID is presented correctly! :)
    Thank you very much for the help! Very much appreciated!
    /J
