callflow$
Discussion in 'CRM / Helpdesk / App Integration' started by zensoftware, Sep 21, 2009.
  1. zensoftware
    zensoftware New Member
    Aug 23, 2007
    225
    In trying to build the example application, when I click on the Variable Selevtor, I dont get callflow$ in the box, instead I get project$, DatabaseName etc.
    Have I missed something out?
    Emmet
  2. VAD_Support
    VAD_Support Active Member
    Aug 6, 2009
    690
    You need to create callflow variables to see them listed as properties of callflow$.
    Project variables can be used and shared around all the project, between callflows and user components. Callflow variables are visible only in the current document (callflow or user component). You can add callflow variables using the properties window when you select a callflow file.
