Solved Callhistory-button indicates missed call on reprovisioning
Discussion in 'Android' started by Severin Meyer, Mar 8, 2018.
Tags:
  1. Severin Meyer
    Jul 29, 2017
    39
    Whenever I restart or reprovision the 3CX-Android client, the callhistory button is blue, indicating a missed call.
    When the button is pressed, the button is not blue anymore, until restart or reprovisioning.
    Samsung Galaxy S8
    Android 7.0
    3CX 15.5.293
    BTW: Could you please extend the info page of the app to show operating system and model of the phone.
  2. Marios Neophytou
    Marios Neophytou Support Team
    Mar 1, 2016
    240
    12
    Thank you for your feedback. You are using the beta version of Android and I assume that you are also using the latest PBX version 15.5.8801.
    However, there are some changes also on the PBX side regarding the whole notification mechanism which are not released yet.
    Thank you
  3. Severin Meyer
    Jul 29, 2017
    39
    My PBX is 15.5.9348.3
    In the morning the button was not blue anymore. Also on restarts.
    But as soon as I have at least one missed call, the button is getting blue again.
    I have now reverted to 15.5.280, but the problem is the same.
  4. Severin Meyer
    Jul 29, 2017
    39
    I can make the button blue again, just by going to settings -> account -> back -> back.
    I think as soon as the list of accounts was shown, there will be a reprovisioning invoked.
  5. Marios Neophytou
    Mar 1, 2016
    240
    12
    Could you please delete all the call history and make just one missed call on your phone
    and try again the same scenario i.e. click on the call history button and then re-provision and check if the blue notification is still appears.
  6. Severin Meyer
    Jul 29, 2017
    39
    I have done this before.
    Clearing the history on the client works, as the list is empty afterwards, but the button is still getting blue. Clicking on the button will just present an empty list.
    So I have now checked the if the list is empty on the webclient.
    The list is empty, but there is a red circle with the number 1 in it. So the PBX is really thinking there is something missed.
    I have now rebooted the PBX and it is now working as it should.
    Seems that the state of the extension was not correctly updated.
    So the problem is solved with a PBX reboot.
  7. Marios Neophytou
    Mar 1, 2016
    240
    12
    I will have a look about this
    Glad to hear that your problem have been solved
    Thank you
