CallHistory.log
Discussion in '3CX Phone System - General' started by galal202, Jan 10, 2010.
  1. galal202
    galal202 New Member
    Jun 23, 2008
    235
    Hello Nick Galea
    Hello every one
    so I wonder if you can store the call history data immediately and direct into the file named by date at callhistory folder
    so I can deal with it from my old dos program
    I need your help because untill version 7 callhistory.log file was have the call details immediately and keep all information about the calls into the same file
    now it appear for second then desapear and store the data at callhistory folder under file named by date
    I did my own software to store this data in database file dos version to make it work with the old data and system
    Thank You
