callhistory2 table problem
Discussion in '3CX Phone System - General' started by etsik, Oct 8, 2008.
  1. etsik
    Apr 16, 2008
    13
    I recently upgraded my 3CX to 6.1.0 from ver6.0.806.
    It stopped writing new calls into callhistory2 table.
    I can stll select the calls made before the upgrade.
    Is there a bug??
  2. radcomp
    Aug 21, 2008
    35
    apparantly with the new upgrade this no longer works. but be assured that i aswell as many others are working on this
    Regards
    Josh
    0353681761
