Calling Cell Phone Using Extension
Discussion in '3CX Phone System - General' started by DuNuNuBatman, Apr 6, 2007.
  1. DuNuNuBatman
    Feb 26, 2007
    13
    I'm trying to set up an extension I can use to automatically call my cell phone. So when I dial 101, it will call my cell phone, but when I set it up in my ring group the cell number is never dialed.
  2. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,994
    306
    I would not use a ring group for that. Create an extension, then use the forward all calls option in the extension screen. Ensure you include the prefix, just as you would dial it from the extension itself.
  3. DuNuNuBatman
    Feb 26, 2007
    13
    Would it still ring to both phones?
  4. Nick Galea
    Jun 6, 2006
    1,994
    306
    I understand what you mean now. We will have to test this. Just to confirm: You have configured a ring group with 2 extensions. 1 of them is forwarded to a cell phone. When you call the extension directly, it works fine. If you call ring group, only the phone which does not forward rings, and the one that forwards does not ring. We'll check, if its a bug well fix it....
  5. DuNuNuBatman
    Feb 26, 2007
    13
    Yup, exactly.
    That could be a good feature to add though. So each extension had the ability to ring at both their sip phone and an external line without having to set up a ring group.
