Calling from a virtual extention
Discussion in '3CX Phone System - General' started by KenC, Oct 5, 2012.
  1. KenC
    Mar 29, 2012
    85
    I've got an extension defined that has no phone. I use MYPHONE to listen to messages left at this extension's mailbox.
    When I try to make an outside call from MYPHONE logged onto this extension, it says I can't since it isn't registered.
    Is there a way to route the call from this (virtual) extension through a real extension? Or to make an outside call from MYPHONE through the pbx -> gateway -> pots line?
    Thank you
  2. paul1
    Jan 14, 2010
    80
    In the "Settings -> Preferences -> Dialing" section of MyPhone you have some options:
    1. You could launch 3CXPhone on the local PC to place the call. I suppose the 3CXPhone could be provisioned for any extension you wish.
    2. You could trigger the call on a desk phone using a specific URL. (If your phone supports this.)
    Paul
  3. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,061
    56
    Ken -
    I think we answered this in your earlier post regarding the same issue. Simply put, there is no way to make a call without having a real interface of some type - be it a softphone, an IP phone, etc.
  4. KenC
    Mar 29, 2012
    85
    Thanks to everyone.
