Calling Internal Extensions is slow
Discussion in '3CX Phone System - General' started by casualmikey, Jul 25, 2010.
  1. casualmikey
    Jul 24, 2010
    21
    Hi, I've installed 3cx and so far the system is great and fairly easy to configure. I purchased the SPA501G to test basic functionality and got the phones configured using provisioning. However when I try to call an internal extension, it takes about 6 seconds to ring. Any idea why this might be happening? I thought it might be router or switch but softphone does not have delay.
    Any ideas would be helpful.
    Thanks.
    11,283
    360
    The majority (if not all) VoIP "hardphones" have a built in delay, generally abut 5 seconds, this is sometimes adjustable. This is to ensure you have dialed all of your digits before sending them all off to the VoIP provider, in this case 3CX. The soft phone doesn't have that issue because, like a mobile phone, you hit "send" after the last digit.You can modify the internal dialplan on the 501 so that it knows when to send off certain combination's of numbers with out waiting the 6 seconds.
    This is only one of many sites that give some help on "crafting" a dialplan in a Linksys device. http://www.scribd.com/doc/238209/LinksysSipura-Dial-Plan-tutorial
  3. mfm
    mfm Active Member
    Mar 4, 2010
    641
    Yes the cisco have a 10 second wati time by default, you could adjust the interdigit timeout to be 3 seconds if you want or you could simply press send on the phone or #, creating a dial plan is a bit tricky to set up if you are inexperienced in writing them, my opinion would be to adapt salmming the # button after dialing the number you want.
  4. casualmikey
    Jul 24, 2010
    21
    I tried using the # key after the extension and that works just great as a workaround. Thank you both very much for the prompt and intuitive feedback. So far I'm very happy with the system.
    Mike
  5. sigma1
    sigma1 Active Member
    Nov 20, 2009
    542
    # works for Grandstream as well
