Calling remote extensions
Discussion in '3CX Phone System - General' started by bluestar, May 25, 2011.
  1. bluestar
    Jan 6, 2011
    12
    Hi All,
    Odd one here, not sure if it's a V10 problem specifically, but I cannot make calls to remote extensions. Remote extensions register OK, and they can make calls into internal extensions and external numbers. Internal extensions can also call external numbers via our VoIP provider withy no problem.
    Firewall checker reports all OK.
    Will post log's if necessary, but thought it might be a simple fix.
  2. davidbenwell
    davidbenwell Active Member
    Apr 27, 2010
    704
    on the remote extension profile within 3CX can you see if
    Supports Re-Invite is enabled, if so try turning this off and test again and let me know how you get on.
