CallNotifier - cmd-line api doesn't work
Discussion in '3CX Phone System - General' started by apfeltalk, Jul 9, 2011.
  1. apfeltalk
    Jan 3, 2011
    Hi everybody!
    I just upgraded from v9 to v10 and want to rebuild my crm-integration:
    So I called
    C:\ProgramData\3CXMyPhone Client Addin\CallNotifier.exe -cmd makecall:12345
    but nothing happens. Maybe the license key? At the moment it is the commercial demo key.
    Thanks!
  2. apfeltalk
    Jan 3, 2011
    Another problem:
    The new myphone app transfers in the %callid% variable the calling number of the queue, in my case the number 80 - and not the callid of the caller.
    Seems to be a bug - help!
