Calls abort after 24 seconds
Discussion in '3CX Phone System - General' started by pjmeulen, Dec 1, 2010.
  1. pjmeulen
    Jun 27, 2008
    We have an Vigor 2820 router and configured it with Qos like descriped in this article:
    http://www.3cx.com/blog/voip-howto/draytek-firewall-voip/
    Dos Defense is not activated.
    Still all voip calls are aborted after 30 seconds.
    I have disabled Stun server because one of my voip providers asked for that.
    Is it therefore that my calls are aborted?
    Where can i find how to make NAT mapping on the Vigor 2820
  2. mfm
    mfm Active Member
    Mar 4, 2010
    641
    It sounds like 3CX is not receiving the ACK. Your guess would be correct it is NAT issues.
    http://portforward.com/english/routers/port_forwarding/Draytek/Vigor-2800G/3CX.htm
    This is the closest router i could find to yours.
    Best of luck!
  3. hornetsoft
    Nov 6, 2009
    16
    if your router support sip alg switch it off I have had this problem loads of times and its worked for me on several routers not sure if there are any other problems caused by switching it off
  4. hornetsoft
    Nov 6, 2009
    16
    Seems that you need to do this via telnet.
    sys sip_alg ?
    Should return the current status.
    usage: sys sip_alg [value]
    0 - disable SIP ALG
    1 - enable SIP ALG
