Calls denied on WiFi phone
Discussion in '3CX Phone System - General' started by gary2seven, Oct 14, 2009.
  1. gary2seven
    Sep 18, 2009
    48
    We have a new 3cx V8 install, I have 3cx SoftPhones working on a number of pc's both inside and outside the firewall.
    Next Step is to configure a WiFi phone that one of our staff will use (It's a Doro ip700wifi), I have configured the WLAN in both the office (WiFi Access point is inside Firewall) and also for WLAN at home.
    Phone registers and I can receive calls on it, but whenever I try and make a call it is denied (see log below).
    I can get the 3CX SoftPhone working on a laptop using WiFi on same networks, so I can see that its a port config.
    Any ideas?
    Gary.
    Code:
    07:41:15.115  [CM503008]: Call(78): Call is terminated
    07:41:15.115  [CM502001]: Source info: From: "Accounts"<sip:108@pbx.hotec.co.uk>;tag=799520101255506066<sip:110@pbx.hotec.co.uk>
    07:41:15.115  [CM503013]: Call(78): Incoming call rejected, caller is unknown; msg=SipReq:  INVITE 110@pbx.hotec.co.uk tid=Ptq80243UNz1VBPkZ4eqep01JYQDe2qO cseq=INVITE contact=108@192.168.1.212:5060 / 91 from(wire)
    07:41:14.756  [CM500002]: Unidentified incoming call. Review INVITE and adjust source identification:
      INVITE sip:110@pbx.hotec.co.uk;transport=UDP SIP/2.0
      Via: SIP/2.0/UDP 192.168.1.212:5060;branch=z9hG4bKoZ2z1r7bFZ3udz5R4by0xr3Ab6Jq3fRb;rport=5060
      Max-Forwards: 70
      Route: <sip:pbx.hotec.co.uk;lr>
      Contact: "Accounts"<sip:108@192.168.1.212:5060>
      To: <sip:110@pbx.hotec.co.uk>
      From: "Accounts"<sip:108@pbx.hotec.co.uk>;tag=25068656631255506066
      Call-ID: 2336660098@localhost
      CSeq: 90 INVITE
      Expires: 180
      Allow: INVITE, ACK, SUBSCRIBE, NOTIFY, BYE, CANCEL, OPTIONS, MESSAGE
      Supported:
      User-Agent: USERAGENT
      Content-Length: 0
    07:41:14.756  [CM302001]: Authorization system can not identify source of: SipReq:  INVITE 110@pbx.hotec.co.uk tid=oZ2z1r7bFZ3udz5R4by0xr3Ab6Jq3fRb cseq=INVITE contact=108@192.168.1.212:5060 / 90 from(wire)
    07:31:12.545  [CM503008]: Call(77): Call is terminated
    07:31:12.545  [CM502001]: Source info: From: "Accounts"<sip:108@pbx.hotec.co.uk>;tag=39523867681255505464<sip:110@pbx.hotec.co.uk>
    07:31:12.545  [CM503013]: Call(77): Incoming call rejected, caller is unknown; msg=SipReq:  INVITE 110@pbx.hotec.co.uk tid=TGF4DOOVk831bnQmy7S0I3Z7qvC400it cseq=INVITE contact=108@192.168.1.212:5060 / 85 from(wire)
    07:31:12.155  [CM500002]: Unidentified incoming call. Review INVITE and adjust source identification:
      Via: SIP/2.0/UDP 192.168.1.212:5060;branch=z9hG4bKa7bX31POIUE3e20134TjWqu3sm2FJH4n;rport=5060
      Max-Forwards: 70
      From: "Accounts"<sip:108@pbx.hotec.co.uk>;tag=8251637251255505463
      Call-ID: 2502672776@localhost
      CSeq: 84 INVITE
      Expires: 180
      Supported:
      Content-Length: 0
    07:31:12.155  [CM302001]: Authorization system can not identify source of: SipReq:  INVITE 110@pbx.hotec.co.uk tid=a7bX31POIUE3e20134TjWqu3sm2FJH4n cseq=INVITE contact=108@192.168.1.212:5060 / 84 from(wire)
    07:30:27.835  [CM503008]: Call(76): Call is terminated
    07:30:27.835  [CM502001]: Source info: From: "Accounts"<sip:108@pbx.hotec.co.uk>;tag=39430362941255505419<sip:110@pbx.hotec.co.uk>
    07:30:27.835  [CM503013]: Call(76): Incoming call rejected, caller is unknown; msg=SipReq:  INVITE 110@pbx.hotec.co.uk tid=7APqF3sGLkh2vMHPV3GkiE94BK8ze44f cseq=INVITE contact=108@192.168.1.212:5060 / 47 from(wire)
    07:30:27.492  [CM500002]: Unidentified incoming call. Review INVITE and adjust source identification:
      Via: SIP/2.0/UDP 192.168.1.212:5060;branch=z9hG4bKio8eDFS8BG2YQP6G29Utfx12JQzm3HTJ;rport=5060
      Max-Forwards: 70
      From: "Accounts"<sip:108@pbx.hotec.co.uk>;tag=3503296751255505418
      Call-ID: 4194025214@localhost
      CSeq: 46 INVITE
      Expires: 180
      Supported:
      Content-Length: 0
    07:30:27.492  [CM302001]: Authorization system can not identify source of: SipReq:  INVITE 110@pbx.hotec.co.uk tid=io8eDFS8BG2YQP6G29Utfx12JQzm3HTJ cseq=INVITE contact=108@192.168.1.212:5060 / 46 from(wire)
    07:30:07.727  [CM503008]: Call(75): Call is terminated
    07:30:07.727  [CM502001]: Source info: From: "Accounts"<sip:108@pbx.hotec.co.uk>;tag=34874813881255505399<sip:110@pbx.hotec.co.uk>
    07:30:07.727  [CM503013]: Call(75): Incoming call rejected, caller is unknown; msg=SipReq:  INVITE 110@pbx.hotec.co.uk tid=3PBlt3GAXKbNSkM52aFNDY4jWt8a42zp cseq=INVITE contact=108@192.168.1.212:5060 / 93 from(wire)
    07:30:07.352  [CM500002]: Unidentified incoming call. Review INVITE and adjust source identification:
      Via: SIP/2.0/UDP 192.168.1.212:5060;branch=z9hG4bKOL48b3tTU9o3YdjWa1TzNIk2A1iQ39k9;rport=5060
      Max-Forwards: 70
      From: "Accounts"<sip:108@pbx.hotec.co.uk>;tag=26928778171255505398
      Call-ID: 3693875300@localhost
      CSeq: 92 INVITE
      Expires: 180
      Supported:
      Content-Length: 0
    07:30:07.352  [CM302001]: Authorization system can not identify source of: SipReq:  INVITE 110@pbx.hotec.co.uk tid=OL48b3tTU9o3YdjWa1TzNIk2A1iQ39k9 cseq=INVITE contact=108@192.168.1.212:5060 / 92 from(wire)
    07:29:30.630  [CM503008]: Call(74): Call is terminated
    07:29:30.630  [CM502001]: Source info: From: "Accounts"<sip:108@pbx.hotec.co.uk>;tag=17511399061255505362<sip:110@pbx.hotec.co.uk>
    07:29:30.630  [CM503013]: Call(74): Incoming call rejected, caller is unknown; msg=SipReq:  INVITE 110@pbx.hotec.co.uk tid=9PTfT4kCwBm25usHE2qGTjo1vtn1I2KB cseq=INVITE contact=108@192.168.1.212:5060 / 59 from(wire)
    07:29:30.318  [CM500002]: Unidentified incoming call. Review INVITE and adjust source identification:
      Via: SIP/2.0/UDP 192.168.1.212:5060;branch=z9hG4bKCG6UiFi9yRO7B3q2bO05XA7nNt3t86Qr;rport=5060
      Max-Forwards: 70
      From: "Accounts"<sip:108@pbx.hotec.co.uk>;tag=28750405991255505361
      Call-ID: 931409722@localhost
      CSeq: 58 INVITE
      Expires: 180
      Supported:
      Content-Length: 0
    07:29:30.318  [CM302001]: Authorization system can not identify source of: SipReq:  INVITE 110@pbx.hotec.co.uk tid=CG6UiFi9yRO7B3q2bO05XA7nNt3t86Qr cseq=INVITE contact=108@192.168.1.212:5060 / 58 from(wire)
    07:29:11.894  [CM504001]: Ext.108: new contact is registered. Contact(s): [sip:108@192.168.1.212:5060/108]
      Expires: 180
      Supported:
      Content-Length: 0
      Expires: 180
      Supported:
      Content-Length: 0
      Expires: 180
      Supported:
      Content-Length: 0
      Expires: 180
      Supported:
      Content-Length: 0
    07:29:10.428  [CM504002]: Ext.108: a contact is unregistered. Contact(s): []
    07:26:42.695  [CM504002]: Ext.110: a contact is unregistered. Contact(s): [sip:110@192.168.1.209:54551;rinstance=c23f20661294c0fd/110]
    07:26:37.406  [CM503007]: Call(73): Device joined: sip:108@192.168.1.212:5060
    07:26:32.742  [CM505001]: Ext.108: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [USERAGENT] PBX contact: [sip:108@192.168.1.50:5060]
    07:26:31.556  [CM503025]: Call(73): Calling Ext:Ext.108@[Dev:sip:108@192.168.1.212:5060]
    07:26:31.509  [CM503010]: Making route(s) to <sip:108@192.168.1.50:5060>
    07:26:31.494  [CM503001]: Call(73): Incoming call from Ext.110 to <sip:108@192.168.1.50:5060>
    07:19:30.291  [CM502001]: Source info: From: "Accounts"<sip:108@pbx.hotec.co.uk>;tag=34971810201255504761<sip:110@pbx.hotec.co.uk>
    07:19:29.917  [CM500002]: Unidentified incoming call. Review INVITE and adjust source identification:
      Via: SIP/2.0/UDP 192.168.1.212:5060;branch=z9hG4bKqBABFNpZwv1SIobU3dYRyR1C5WGCTGzE;rport=5060
      From: "Accounts"<sip:108@pbx.hotec.co.uk>;tag=5331147291255504761
      CSeq: 96 INVITE
      Expires: 180
      Supported:
      Content-Length: 0
      Expires: 180
      Supported:
      Content-Length: 0
      Expires: 180
      Supported:
      Content-Length: 0
      CSeq: 96 INVITE
    11,105
    329
    If the phone is set up to work ONLY within your LAN then you shouldn't see something like this...108@pbx.hotec.co.uk
    Was the WiFi phone originally set up to work from an outside LAN, do you have STUN enabled on it? You shouldn't if you are using it from within the LAN. All the settings in the phone should consist of internal IPs only.
    The WiFi phones that I've used have allowed me to set up multiple network profiles so I can have one set of parameters for use within the office/ local LAN and one set to use when travelling.
  3. gary2seven
    Sep 18, 2009
    48
    The phone has been setup to work both inside and outside the local network. We have configured all our devices to use pbx.hotec.co.uk, the internal DNS points to a local IP the external DNS points to our external address. This was suggested by Kerry Garrison on this forum and is working well on all devices.
    I'll check the STUN settings.
    Gary.
  4. leejor
    11,105
    329
    Try using an IP address in place of the DNS in the phone, just for testing, see if it makes a difference.
