Calls drop when answered with a headset
Discussion in '3CX Phone System - General' started by adamwells, Jun 4, 2015.
  1. adamwells
    Mar 20, 2015
    25
    One of my users has noticed when she answers an incoming call using her headset, the call will drop after exactly 5 seconds. Can anyone point me in the right direction as to why this may be happening?
    Other users use the same headsets and it doesn't happen.
    11,127
    330
    What type of headset? Make/model, USB, mic/headphones connector?
    Given that one user is having an issue, and no others are,( I assume they all use the same type of headset), then I would suspect a driver issue, on that one machine.
    Have you tried swapping out the headset with one that has been working on another machine?
    I also assume that this is using the 3CX phone? Which version are you using?
