Calls Dropping to Australia after 7-10 seconds
Discussion in '3CX Phone System - General' started by Andy Veal, Oct 5, 2017.
  1. Andy Veal
    Oct 5, 2017
    61
    We are using Faktortel as our SIP provider for calls to AU and have an issue with calls dropping after 7-10 seconds.
    We have cloud based server and I have captured packets using wireshark which shows the BYE coming from the PBX, currently the only way to fix this is by restarting the phonesystem 01 SIP server service via the console 3-4 times a day.
  2. GiannosC_3CX
    GiannosC_3CX Guest
    Hi Andy,
    I have sent you a P.M. Please check your inbox.
