Calls ended always 30 seconds
Discussion in '3CX Phone System - General' started by ilkeryildiz, May 7, 2007.
  1. ilkeryildiz
    Jan 7, 2007
    26
    external to external calls ended always 30 seconds.
    there aren't this problem previous version.
    v3.0.1928.0 log:
    18:12:05.640 StratLink::eek:nHangUp Call(C:49): Ext.202 hung up call; reason: ???
    18:11:33.484 CallLegImpl::eek:nConnected Call(C:49): Created audio channel for Ext.201 (85.97.135.206:50758) with third party (81.213.108.235:5100)
    18:11:33.484 StratInOut::eek:nConnected Call(C:49): Setup completed for call from Ext.202 to Ext.201
    18:11:33.484 CallLegImpl::eek:nConnected Call(C:49): Created audio channel for Ext.202 (81.213.108.235:5100) with third party (85.97.135.206:50758)
    18:11:29.218 CallConf::eek:nProvisional Call(C:49): got response from 201
    18:11:28.937 CallConf::eek:nIncoming Call(C:49): Incoming call from Ext.202 to sip:201@sibertelefon.com
  2. Anonymous
    Anonymous Guest
    More info required mate.
    Type of ATA
    Type of Connection eg ISDN, ADSL etc.
    Phones used
    Disconnect after 30 seconds, is either SIP registration or/and NAT.
    In the first instance try to enable stun server.
  3. ilkeryildiz
    Jan 7, 2007
    26
    zyxel, Billion ata, router.
    ADSL internet
    no problem sip registration
    its good works last week but there are this problem 2-3 days.
    no any change.
    I uninstall and reinstall 3cx but same problem
    I install another pc and network but same problem.
    there are same problem external to voip line calls.
    its a few hours good works when I was restart server.
  4. ilkeryildiz
    Jan 7, 2007
    26
    Disconnect after 30-35 seconds
    15:01:46.062 StratLink::eek:nHangUp Call(C:29): Ext.201 hung up call; reason: ???
    15:01:13.796 CallLegImpl::eek:nConnected Call(C:29): Created audio channel for Ln:20001@borsamatik@lowratevoip (195.219.64.168:8404) with third party (85.101.12.218:59074)
    15:01:13.796 StratInOut::eek:nConnected Call(C:29): Setup completed for call from Ext.201 to Ln:20001@borsamatik@lowratevoip
    15:01:13.796 CallLegImpl::eek:nConnected Call(C:29): Created audio channel for Ext.201 (85.101.12.218:59074) with third party (195.219.64.168:8404)
    15:01:11.296 CallConf::eek:nProvisional Call(C:29): got response from 00902165280100
    15:01:11.281 CallConf::eek:nProvisional Call(C:29): got response from 00902165280100
    15:01:10.609 CallConf::eek:nIncoming Call(C:29): Incoming call from Ext.201 to sip:02165280100@sibertelefon.com
  5. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,939
    250
    With this information its difficult to help. You have not detailed what equipment you are doing to cause this error and exactly what type of phones you are using. You meantion ATA, Billion, zyxel but what are they.
    Youll need to detail these, including provider in use, exact sequence (i.e extension to provider) Always same extension or different ones.
  6. ilkeryildiz
    Jan 7, 2007
    26
    Zyxel ata -extension number 204 :
    Advanced options:
    Extension is external :checked
    Bind to Media Server :unchecked
    Supports Re-Invite :checked
    Supports 'Replaces' header :checked
    Billion ata -extension number 202 :
    Advanced options:
    EyeBeam Softphone -extension number 201 :
    Advanced options:
    All external extension on separate adsl internet.
    Voip provider :Betemax (lowratevoip.com)
    Advanced options:
    Extension is external : checked
    Bind to Media Server : unchecked
    Supports Re-Invite : checked
    Supports 'Replaces' header : unchecked
    there are this problem external to voip provider line and external to external calls.
    no any change my 3cx system server.
    I install another pc and network at home but same problem.
    3CX v3.0.1928.0 on windows 2003 SP2 + MS ISA 2006.
  7. sittsh
    May 2, 2007
    19
    try setting bind to media server
    and make sure all equiptment is set to use codec g 711a or g711u for receive and transmit.
    when negotiating codec type if 3cx doesnt see either of these codecs for the receive or tranmit iv'e seen it drop the call after about 20-30 seconds.
    also check your netork settings if your bewind i firewall make sure all your ports for 3cx are opend and i your behind a nat make sure all the proper ports are redirected to the proper ip.
    if it worked before and absolutely not i single thing changed i would reboot the 3cx server, the ata, and all other hardware and software your useing.
    alse if your pc has a pc firewall running(turned on) try to turn it off.
  8. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    Please, try to bind all extensions and provider to media server. If this doesn't help - than, please, provide our support with logs and settings.
