Calls external sound in server machine - Skype
Discussion in '3CX Phone System - General' started by gambino_sergio, May 7, 2012.
  1. gambino_sergio
    May 7, 2012
    Good morning. We have in our oficce 3 machines with 3CX softphone. 3CX Phone System is running in one of them and the outline is a Skype account. The issue is:
    - The person using the machine running the 3CX phone system can hear the incoming audio of any call. I went over the forums but I couldn´t get a solution. Anybody can help me with this?
    The Phone System is updated. The sofphone is updated.
    Thanks in advance.
    Sergio Gambino.
    10,368
    228
    Do you mean the audio of Skype calls? If so, then yes, this is how it works. The 3CX Skype Gateway makes use of the audio components in the PC that they (3CX and the gateway) are running on. I would suggest that you run them on a PC that does not have speakers plugged into it.
  3. gambino_sergio
    May 7, 2012
    That´s is what I mean. Thanks for your quick reply.
    Sergio.
