Calls fade away
Discussion in '3CX Phone System - General' started by jofer, Dec 5, 2012.
  1. jofer
    Dec 5, 2012
    45
    Hi all
    I experience calls fading away, going softer and softer and completely silent, then back to normal in the same call. It started off with one or 2 users and now almost through the system. V11 with about 200 yealink phones, and ISDN connected on Berofix gateway.
    Also the server is running on virtual machine with windows 2008 R2 server platform.
    Any suggestions?
    Regards
    Johan
  2. 3CXfoxhallsolutions
    3CXfoxhallsolutions New Member
    Sep 8, 2012
    211
    First thoughts are to determine if this is dependent on the Berofix?
    I've got systems running on VM's with no issues like this, so I'd suggest that you confirm that;
    a) You DON'T get this problem when making internal extension to extension calls?
    and ...
    b) Is it possible that you could set up a cheap SIP Trunk service that you can then make outgoing calls on and compare???
    This is a very strange problem, so you are going to need to do some 'process of elimination' type detective work!
    Good luck
  3. jofer
    Dec 5, 2012
    45
    Thank you for the reply, yes I will register an SIP account and compare, it may be the gateway.
    Will keep you posted.
    Regards
    Johan
