Calls from 3CXPhone extension doesn't ring other extensions
Discussion in 'Windows' started by jholcombe, Jun 30, 2015.
  1. jholcombe
    Jul 9, 2014
    79
    I have a 3CXPhone with extension 765. I have a Yealink T46G with extension 281. If I call 765 from 281, 765 will ring. If I call 281 from 765, it will stay quiet for a while (no rings) and then I'll hear a brief ring and get forwarded to the voicemail for 281. Extension 281 never rings.
    I have another Yealink T64G with extension 333. I can call 333 from 281 and 281 from 333 with no problems. Both will ring.
    I can place outside calls with 3CXphone. I can receive inbound calls with 3CXphone. The only thing I can't seem to do is ring an internal extension with 3CXphone, even from the same LAN. Does anyone have any suggestions?
    Thanks,
    --John
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,545
    298
    Re: Calls from 3CXPhone extension doesn't ring other extensi
    this appears to be a dupe of a thread in the General Forum.
  3. IliasL_3CX
    3CX Support
    Jun 2, 2014
    74
    Hi John,
    How was the 3CX Phone configured ? via the Management Console/Welcome Email or manually ?
    Regards
  4. jholcombe
    Jul 9, 2014
    79
    3CXPhone was configured with a welcome e-Mail.
  5. jholcombe
    Jul 9, 2014
    79
    Yes, I apologize, this is a duplicate thread. I wasn't sure if the issue was a 3CXPhone issue or a system issue. Please accept my apologies for this and, if need be, feel free to close this thread. The other thread can be found at: http://www.3cx.com/forums/3cxphone-not-ringing-ip-phones-41519.html
    Thank you!,
    --John
