calls from analog line
Discussion in '3CX Phone System - General' started by birka, Aug 20, 2011.
  1. birka
    Aug 20, 2011
    hi
    i have configured 3cx phone system and it's work fine
    i dont connect to any service provider
    and i want to add an analog line for exteranl calls (to other analog line)
    if i got it right, i need an FXO gateway(like - spa 3102) ,connet it to my analog line
    configure it as a pstn at the 3cx phone system managment
    make rules that says for example if you dial 9XXXXXXX ( 9 - at the beginnig of the number)
    go to the pstn device (spa 3102)
    configured the spa 3102
    and thats it ? now i can make an exteranl calls (to other analog line) from my VOIP-phone ?
    10,855
    300
    Yes, that's pretty much it.
    You may have to do some tweaking on the outbound rules to get all types of numbers to work in your calling area/country.
  3. birka
    Aug 20, 2011
    ok thanks
    is there away to configure an analog line with FXO card on my server (like modem)?
    and use it for exteranl calls without the need for PSTN device ?
  4. leejor
    10,855
    300
    Here is a link to the supported gateway devices.. https://www.3cx.com/voip-gateways/
    I haven't looked through it for a while but there may be a PCI type analogue gateway card that will work with 3CX. The problem with trying to use that type of device is, most don't support just one line, so if that is all you want to use, it's a bit of overkill. Many PC card gateways don't work with Windows. Keep in mind that just because a device isn't on 3CX's supported list, that doesn't mean it won't work. It just means that it has not been tested and you are on your own in getting it to work.
    You can't use a modem card.
  5. willow
    willow Member
    Mar 1, 2011
    471
    Sangoma makes PC I cards though they are expensive. If you are looking at one line. Then check out a grand stream Ht503
  6. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
    Try also Cisco (Linksys) SPA-3102 - probably the best analog gateway.
    Regards
