Calls from number to extension
Discussion in '3CX Phone System - General' started by nibb, Nov 13, 2012.
  1. nibb
    Jul 13, 2011
    16
    Can someone tell if its possible to filter all calls that come from a specific number go directly to an extension?
    Do you do this with the DID rules? Because I tried setting the number there that appears when the income calls come and nothing happens.
    I have one number redirected to a number which is setup as trunk in 3CX and I want call that come from that number to be handled by a specif extension.
  2. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Inbound rules can handle Caller ID instead of DID
    http://www.3cx.com/forums/route-incoming-calls-based-on-the-caller-id-of-the-caller-32160.html?view-post=140768#p140768
