Calls From Remote Phones "Forbidden"
Discussion in '3CX Phone System - General' started by Drew9213, Jan 30, 2017.
  1. Drew9213
    Sep 16, 2015
    62
    Getting a "forbidden" error while dialing out to external numbers as well as internal extensions from my remote phones. This is what I see in my activity log. Regardless of which extension I call from it, it alwas comes up as "sales" in the from field.
    01/30/2017 8:57:55 AM - [CM302001]: Authorization system can not identify source of: UnkSrc Recv Req SUBSCRIBE from PublicIP:61129 tid=2396161925 Call-ID=0_1505921115@PublicIP: SUBSCRIBE sip:SP2@mydomain.com:5060 SIP/2.0 Via: SIP/2.0/UDP PublicIP:61674;rport=61129;branch=z9hG4bK2396161925 Max-Forwards: 70 Contact: <sip:110@PublicIP:61674> To: <sip:SP2@mydomain.com:5060> From: "Sales" <sip:110@mydomain.com:5060>;tag=903293969 Call-ID: 0_1505921115@PublicIPCSeq: 1 SUBSCRIBE Expires: 900 Accept: application/dialog-info+xml Allow: INVITE, INFO, PRACK, ACK, BYE, CANCEL, OPTIONS, NOTIFY, REGISTER, SUBSCRIBE, REFER, PUBLISH, UPDATE, MESSAGE User-Agent: Yealink SIP-T48G 35.80.0.130 Event: dialog Content-Length: 0
    #1 Drew9213, Jan 30, 2017
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,353
    535
    Hello @Drew9213
    Are your phones connected via SBC or STUN? Also navigate to settings/ Network/ FQDN tab and check your local SIP domain. IS that correct?
  3. Drew9213
    Sep 16, 2015
    62
    Connecting via STUN and SIP domain is correct.
  4. Drew9213
    Sep 16, 2015
    62
    I've actually just completely factory reset the remote phones and reprovisioned them and they're working in terms of calling out and other extensions. I'm now having an issue where the remote phones are not seeing presence. So I have BLF's for the other extensions that are showing up grey with an x, but if you hit the button it works just fine.
  5. leejor
    11,086
    326
