Calls go silent during call for 10-15 seconds
Discussion in '3CX Phone System - General' started by davidlunt, Feb 23, 2016.
  1. davidlunt
    Jun 19, 2014
    5
    We have a small voip setup which has been working well, I recently upgraded the PC and reset up our VOIP system and used a backup of the original system, everything seemed to be going well but on quite a few calls the call goes silent during the call and then returns after around 5-10 seconds.
    I have been through all our settings and have double checked the port forwarding and open ports and I'm struggling to find the solution. I have even turned off the Windows firewall and that does not resolve the issue. I have also checked the quality of service and that also seems fine.
    The router is a Draytek Vigor 2820 and 3CX is running off a Windows 7 PC.
    Any pointers of what to look at that may give an indication of the problem?
    I'd be really grateful of any pointers.
    David
  2. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,283
    68
    Hi David,
    I think running a packet capture on the server and analyzing the RTP traffic the server is receiving is the only way to see what is happening here...
  3. davidlunt
    Jun 19, 2014
    5
    Hi Nick
    Thanks for your help, I thought I'd solved the issue but it still seems to be happening. I'm sorry I'm not over technical but if you could help with how to run a packet capture that would be great?
    If I posted the results would you mind casting an eye over them?
    Thanks for your help.
    I really appreciate it.
    David
