Calls Going Right to Voicemail WHY?
Discussion in '3CX Phone System - General' started by thereverend, Jun 19, 2011.
  1. thereverend
    thereverend New Member
    May 29, 2011
    100
    Calls that come in are going right to my voice mail. My phone is working properly and i can make calls from it and it is showing as registered but the calls that are coming in are going right to voicemail. Can someone please tell me what settings to check to make sure it is set up right or whatever.. BUT not all calls go to voicemail only 4 out of 6 do.. but the phone is always on and ready when they do.. I call myself and it goes to vm .. please help!
  2. davidbenwell
    davidbenwell Active Member
    Apr 27, 2010
    704
    We need to see the logs before we can say what the problem is likely to be.
  3. thereverend
    May 29, 2011
    100
    here is the server activity log,.attached
  4. thereverend
    May 29, 2011
    100
    Would not attach as file so here it is
    12:00.625
    [CM503003]: Call(20): Call to sip:210@192.168.1.109 has failed; Cause: 487 Request Cancelled; from IP:192.168.1.108:50567
    08:12:00.419
    [CM503008]: Call(20): Call is terminated
    08:11:57.632
    [CM505001]: Ext.210: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Cisco-CP7960G/8.0] PBX contact: [sip:210@192.168.1.109:5060]
    08:11:57.632
    [CM503002]: Call(20): Alerting sip:210@192.168.1.108:5060;transport=udp
    08:11:57.335
    [CM503025]: Call(20): Calling Ext:Ext.210@[Dev:sip:210@192.168.1.108:5060;transport=udp]
    08:11:57.295
    [CM503004]: Call(20): Route 1: Ext:Ext.210@[Dev:sip:210@192.168.1.108:5060;transport=udp]
    08:11:57.291
    [CM503010]: Making route(s) to <sip:210@192.168.1.109:5060>
    08:11:57.284
    [CM505003]: Provider:[CallCentric - US] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] PBX contact: [sip:17772209598@68.68.178.107:5060]
    08:11:57.238
    [CM503001]: Call(20): Incoming call from 15185773549@(Ln.10000@CallCentric - US) to <sip:210@192.168.1.109:5060>
    08:11:57.166
    [CM503012]: Inbound out-of-office hours rule (unnamed) for 10000 forwards to DN:210
    08:01:27.830
    [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 96.9.132.83:3478 over Transport 192.168.1.109:5060
    07:41:27.163
    07:21:27.180
    07:01:27.205
    06:45:35.041
    [CM503008]: Call(19): Call is terminated
    06:45:28.632
    [CM503007]: Call(19): Device joined: sip:999@127.0.0.1:40600;rinstance=d0e9ccce0d3d77fb
    06:45:28.610
    [CM503007]: Call(19): Device joined: sip:210@192.168.1.108:5060;transport=udp
    06:45:28.580
    [CM505001]: Ext.999: Device info: Device Identified: [Man: 3CX Ltd.;Mod: Voice Mail Menu;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX Voice Mail Menu] PBX contact: [sip:999@127.0.0.1:5060]
    06:45:28.579
    [CM503002]: Call(19): Alerting sip:999@127.0.0.1:40600;rinstance=d0e9ccce0d3d77fb
    06:45:28.338
    [CM503025]: Call(19): Calling Ext:Ext.999@[Dev:sip:999@127.0.0.1:40600;rinstance=d0e9ccce0d3d77fb]
    06:45:28.299
    [CM503004]: Call(19): Route 1: Ext:Ext.999@[Dev:sip:999@127.0.0.1:40600;rinstance=d0e9ccce0d3d77fb]
    06:45:28.296
    [CM503010]: Making route(s) to <sip:999@192.168.1.109>
    06:45:28.289
    06:45:28.257
    [CM503001]: Call(19): Incoming call from Ext.210 to <sip:999@192.168.1.109>
    06:41:26.320
    06:21:26.378
    06:01:26.442
    05:41:25.294
    05:21:25.354
    05:01:25.365
    04:41:24.473
    04:21:24.506
    04:08:19.825
    [CM503008]: Call(18): Call is terminated
    04:08:18.289
    [CM503007]: Call(18): Device joined: sip:210@192.168.1.108:5060;transport=udp
    04:08:18.264
    [CM503007]: Call(18): Device joined: sip:17772209598@callcentric.com:5060
    04:08:07.881
    04:08:07.880
    [CM503002]: Call(18): Alerting sip:210@192.168.1.108:5060;transport=udp
    04:08:07.580
    [CM503025]: Call(18): Calling Ext:Ext.210@[Dev:sip:210@192.168.1.108:5060;transport=udp]
    04:08:07.538
    [CM503004]: Call(18): Route 1: Ext:Ext.210@[Dev:sip:210@192.168.1.108:5060;transport=udp]
    04:08:07.534
    04:08:07.527
    04:08:07.492
    [CM503001]: Call(18): Incoming call from anonymous@(Ln.10000@CallCentric - US) to <sip:210@192.168.1.109:5060>
    04:08:07.420
    04:07:39.905
    [CM503008]: Call(17): Call is terminated
    04:07:26.980
    Currently active calls - 1: [17]
    04:07:21.295
    [CM503007]: Call(17): Device joined: sip:999@127.0.0.1:40600;rinstance=d0e9ccce0d3d77fb
    04:07:21.273
    [CM503007]: Call(17): Device joined: sip:210@192.168.1.108:5060;transport=udp
    04:07:21.243
    04:07:21.242
    [CM503002]: Call(17): Alerting sip:999@127.0.0.1:40600;rinstance=d0e9ccce0d3d77fb
    04:07:21.005
    [CM503025]: Call(17): Calling Ext:Ext.999@[Dev:sip:999@127.0.0.1:40600;rinstance=d0e9ccce0d3d77fb]
    04:07:20.964
    [CM503004]: Call(17): Route 1: Ext:Ext.999@[Dev:sip:999@127.0.0.1:40600;rinstance=d0e9ccce0d3d77fb]
    04:07:20.962
    04:07:20.954
    04:07:20.920
    [CM503001]: Call(17): Incoming call from Ext.210 to <sip:999@192.168.1.109>
    04:01:24.477
  5. davidbenwell
    Apr 27, 2010
    704
    Hi, i see your using a Cisco 7960?
    Does the phone actually show as registered in 3CX (Green)??
    Do you have out of office hours set?
  6. thereverend
    May 29, 2011
    100
    Yes the phone is Green and shows registered and does not go RED unless unplugged'
  7. davidbenwell
    Apr 27, 2010
    704
    if you install the 3CX Softphone do you still get the same issue?
  8. thereverend
    May 29, 2011
    100
    I have not been able to get the 3cx for android to work. It will not register.
    I have tried the step by step directions and it does not seem to work so i cant even try it.
  9. davidbenwell
    Apr 27, 2010
    704
    please try the windows 3CX Softphone and let me know if that works ok, trying to see if its a Cisco Phone issue or 3CX hints the tests.
  10. thereverend
    May 29, 2011
    100
    It still goes right to VM. Even with the softphone..
    would you be able to log in to my computer remotely and then ill log you into my 3cx to take a look around and see if everything is right in the 3cx system?
  11. thereverend
    May 29, 2011
    100
    It seems if i SHUT down and RESTART 3CX that the system functions for a little while then.. stops..
  12. davidbenwell
    Apr 27, 2010
    704
    Might be a good idea to ask someone to do a remote support session to see what's wrong with your 3CX Phone System, it would be the quickest way of getting this sorted.
  13. thereverend
    May 29, 2011
    100
    Can you do this for me?
  14. davidbenwell
    Apr 27, 2010
    704
    Yes we can, however this is a chargeable service, pm me if you would like me to do this, Available tomorrow between 9am and 6pm UK Time.
  15. thereverend
    May 29, 2011
    100
    What do you get for 1 incident?
  16. thereverend
    May 29, 2011
    100
    Can anyone shed some light on this. I would like to have the system up and running 100% before i go ahead any PAY anymore money for it.
    right now as it sits it is useless to me. I have today even changed out my servers with a FASTER server with MORE memory and DEDICATED only to 3cx at the moment. IIS is not RUNNING nor is any other server programs.. No Firewall etc.. Please help. the phone says registered all the time when the calls are going directly to voicemail so i have no idea whats going on here!
    :evil:
  17. davidbenwell
    Apr 27, 2010
    704
    full info can be found at
    http://www.3cx-phone-system.co.uk/shop/#ecwid:category=886079&mode=product&product=4205695
  18. paul1
    Jan 14, 2010
    80
    Have you looked at the forwarding rules for your extensions? If your setting for "If the call is not answered within xx seconds then... " is to short that could be the problem.
    If you are less than about 10 seconds it could be timing out before you get your first ring. Try extending it to 20 seconds or more to see what happens. Note that there can be different settings for different statuses. (Available Away etc.)
  19. paul1
    Jan 14, 2010
    80
    After looking at your log a little closer I noticed that you are using an "Out-of-Office" status. If you look at the forwarding tab for an extension you will notice that it does not even attempt to ring a phone with Out-of-Office status. Change your status to available and give it a try.
  20. thereverend
    May 29, 2011
    100
    Set at 60 Seconds right now..
    and I have even shut the Voicemail OFF and the Voice Mail will still answer sometimes.
    I do not have the phone set for out of the office. Where would i check to see if this is ENABLED?
    I see the OUT OF THE OFFICE tab but.. there is no ACTIVATE or anything to select or deselect this option.
    I have even tried 2 different phones to make sure it is NOT the phone.. :roll:
