Calls going stright to voice mail
Discussion in 'Windows' started by yerfdog, Feb 3, 2012.
  1. yerfdog
    Feb 3, 2012
    6
    Hi All.
    After getting my 7965 to register on 3CX i have a new problem.
    I can call out from the 7965 fine. If someone was to call me internally it goes stright to voice mail. I have turned of the voice mail for the users but it always go to voice mail.
    Everything is setup the same as the 7941 and 7940 ectension and there is no problem on them.. Only on the 7965's
    My voice mail box is set to 666.
    I was trying to call from 107 ----- 101
    Please could someone take a look at the logs.
    Any help would be great.
    Mike
    INVITE sip:101@192.168.0.250;user=phone SIP/2.0
    Via: SIP/2.0/UDP 192.168.0.28:5060;branch=z9hG4bK431199d5
    Max-Forwards: 70
    Contact: <sip:107@192.168.0.28:5060;transport=udp>
    To: <sip:101@192.168.0.250;user=phone>
    From: "107"<sip:107@192.168.0.250>;tag=0016c8fd658e000c9d6c72ab-abd812a0
    Call-ID: 0016c8fd-658e000a-81a111f9-a1ba9e9a@192.168.0.28
    CSeq: 102 INVITE
    Expires: 180
    Accept: application/sdp
    Allow: ACK, BYE, CANCEL, INVITE, NOTIFY, OPTIONS, REFER, REGISTER, UPDATE, SUBSCRIBE
    Date: Wed, 22 Mar 2006 GMT
    Proxy-Authorization: Digest username="107",realm="3CXPhoneSystem",uri="sip:101@192.168.0.250;user=phone",response="15d20229b0fd02643f139a555b6e5896",nonce="414d535c053ca18b75:2a6f2d4684f3af21dd0757e532848a50",algorithm=MD5
    Supported: replaces, join, norefersub
    User-Agent: Cisco-CP7941G/8.0
    Allow-Events: kpml, dialog
    Content-Length: 0
    Remote-Party-ID: "107" <sip:107@192.168.0.28>;party=calling;id-type=subscriber;privacy=off;screen=yes
    <br>
    16:51:23.746|.\CallCtrl.cpp(346)|Log2||CallCtrl::eek:nIncomingCall:[CM503001]: Call(24): Incoming call from Ext.107 to <sip:101@192.168.0.250;user=phone><br>
    16:51:23.751|.\Extension.cpp(1407)|Log3||Extension::printEndpointInfo:[CM505001]: Ext.107: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Cisco-CP7941G/8.0] PBX contact: [sip:107@192.168.0.249:5060]<br>
    16:51:23.751|.\CallLeg.cpp(1194)|Log5||CallLeg::setRemoteSdp:Remote SDP is set for legC:24.1<br>
    16:51:23.753|.\SLServer.cpp(861)|Log5|MediaServer|MediaServerReporting::SetRemoteParty:[MS210000] C:24.1:Offer received. RTP connection: 192.168.0.28:22854(22855)<br>
    16:51:23.753|.\CallCtrl.cpp(529)|Log3||CallCtrl::eek:nSelectRouteReq:[CM503010]: Making route(s) to <sip:101@192.168.0.250;user=phone><br>
    16:51:23.754|.\CallCtrl.cpp(708)|Log2||CallCtrl::eek:nSelectRouteReq:[CM503004]: Call(24): Route 1: Ext:Ext.101@[Dev:sip:101@192.168.0.36:5060;transport=udp]<br>
    16:51:23.797|.\SLServer.cpp(861)|Log5|MediaServer|MediaServerReporting::SetRemoteParty:[MS210006] C:24.2:Offer provided. Connection(by pass mode): 192.168.0.28:22854(22855)<br>
    16:51:23.799|.\Target.cpp(441)|Log2||Target::makeOneInvite:[CM503025]: Call(24): Calling Ext:Ext.101@[Dev:sip:101@192.168.0.36:5060;transport=udp]<br>
    16:51:42.115|.\Call.cpp(42)|Log3||??:Currently active calls - 1: [24]<br>
    16:51:55.833|.\CallLeg.cpp(326)|Log2||CallLeg::eek:nFailure:[CM503003]: Call(24): Call to sip:101@192.168.0.250 has failed; Cause: 408 Request Timeout; internal<br>
    16:51:55.837|.\CallCtrl.cpp(840)|Log2||CallCtrl::eek:nRerouteReq:[CM503005]: Call(24): Forwarding: Ext:Ext.666@[Dev:sip:666@127.0.0.1:40600;rinstance=661c21fb8beaf794]<br>
    16:51:55.887|.\SLServer.cpp(861)|Log5|MediaServer|MediaServerReporting::SetRemoteParty:[MS210004] C:24.3:Offer provided. Connection(proxy mode): 127.0.0.1:7098(7099)<br>
    16:51:55.889|.\Target.cpp(441)|Log2||Target::makeOneInvite:[CM503025]: Call(24): Calling Ext:Ext.666@[Dev:sip:666@127.0.0.1:40600;rinstance=661c21fb8beaf794]<br>
    16:51:56.095|.\CallLeg.cpp(315)|Log3||CallLeg::eek:nAnswer:[CM503002]: Call(24): Alerting sip:666@127.0.0.1:40600;rinstance=661c21fb8beaf794<br>
    16:51:56.095|.\Extension.cpp(1407)|Log3||Extension::printEndpointInfo:[CM505001]: Ext.666: Device info: Device Identified: [Man: 3CX Ltd.;Mod: Voice Mail Menu;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX Voice Mail Menu] PBX contact: [sip:666@127.0.0.1:5060]<br>
    16:51:56.098|.\CallLeg.cpp(1194)|Log5||CallLeg::setRemoteSdp:Remote SDP is set for legC:24.3<br>
    16:51:56.099|.\SLServer.cpp(861)|Log5|MediaServer|MediaServerReporting::SetRemoteParty:[MS210001] C:24.3:Answer received. RTP connection[unsecure]: 127.0.0.1:40628(40629)<br>
    16:51:56.102|.\SLServer.cpp(861)|Log5|MediaServer|MediaServerReporting::SetRemoteParty:[MS210005] C:24.1:Answer provided. Connection(proxy mode):192.168.0.249:7094(7095)<br>
    16:51:56.104|.\CallCtrl.cpp(885)|Log2||CallCtrl::eek:nLegConnected:[CM503007]: Call(24): Device joined: sip:107@192.168.0.28:5060;transport=udp<br>
    16:51:56.106|.\CallCtrl.cpp(885)|Log2||CallCtrl::eek:nLegConnected:[CM503007]: Call(24): Device joined: sip:666@127.0.0.1:40600;rinstance=661c21fb8beaf794<br>
    16:51:56.583|.\CallLeg.cpp(594)|Log5||CallLeg::eek:nConfirmed:Session 874 of leg C:24.1 is confirmed<br>
    16:51:59.457|.\Call.cpp(1396)|Log2||Call::Terminate:[CM503008]: Call(24): Call is terminated<br>
    10,848
    299
    This indicates that Ext 101 has failed to respond to the INVITE from 3CX within the allotted time, so the call went to voicemail.
    If the set is registering properly (check the log), then you need to figure out (using Wireshark), if the set "gets the message" at all, gets the message but responds to an incorrect destination, or, isn't responding at all.
  3. yerfdog
    Feb 3, 2012
    6
    Thats the thing, I dont see any SIP traffic from that phone in wireshark. I can see all other SIP traffic?
    Very strange?
    Any ideas?
  4. leejor
    10,848
    299
    As I haven't used that particular set, I'm afraid I'm not the one to help diagnose it. You could start from scratch and go over all of the settings again. Try provisioning with some very basic settings. Be sure to verify the network settings.
