Calls incorrectly handled when using multiple ring groups
Discussion in '3CX Phone System - General' started by chris.moses@ekriley.com, Jul 14, 2017.
  1. chris.moses@ekriley.com
    Jul 7, 2016
    9
    I think I've found a bug in the 15.5 build of 3cx. We often use ring groups to catch unanswered calls and this has always worked in the past but now we're getting some very strange behavior in the full 15.5 release.
    Example config:
    * Call comes into extension 1234
    * Call is unanswered for 12 seconds and is forwarded to ring group 9001
    * If call is unanswered by RG 9001 for 12 seconds go to extension 1234 voicemail
    This has worked since we first started using 3CX (v14)
    Currently what happens is:
    * If call is unanswered for 12 seconds, forward to ring group 9001
    * All lines on RG9001 ring for a split second and then *one* of the extensions in the ring group show as connected on the "current calls" window and that extension shows as active. This is despite no one having answered that call and the phone of the extension in question showing no activity at all. The calling party hears ringback until the "ghost" connection happens and then it's just dead audio (but connected).
    This is a huge issue for us. I've tried recreating ring groups and restarting services/servers and it works consistently whenever you forward to a ring group. Inbound DIDs that route directly to a ring group work correctly until they are forwarded to a different ring group and then they have the same behavior.
  2. SECOIT GmbH
    Apr 3, 2017
    66
    19
    Is it always the same extension that "answers" the call? If so, can you remove it from the ring group and see if the issue persists with the other extensions in the group?
  3. chris.moses@ekriley.com
    Jul 7, 2016
    9
    It appears to always "answer" the call with the same extension (per ring group). I tried your suggestion and it just grabbed a different number from the ring group to "answer" however.
  4. leejor
    10,835
    294
    What type (make/model) of "sets" are you using? All the same, or a mix of types? Just wondering if there is a set option that is causing the "answer".
  5. chris.moses@ekriley.com
    Jul 7, 2016
    9
    All are Yealink T48G although we are on a few firmware versions. Again, this config has run for quite a while over different versions of 3CX, this seems just to have started with the latest (full) 15.5 release.
  6. SECOIT GmbH
    Apr 3, 2017
    66
    19
    ooh... just tried to reproduce it out of curiosity.
    Do you feel better when I tell you most of my officially supported phones don't work at all in Ring Groups? :)
    I hardly ever use Ring Groups so I haven't noticed before. Will need to dig a bit deeper...
  7. chris.moses@ekriley.com
    Jul 7, 2016
    9
    Did you get the same behavior? We leverage ring groups extensively because we came from a "shared lines" environment (Cisco) and our users still wish they had shared lines. :'(
  8. SECOIT GmbH
    Apr 3, 2017
    66
    19
    Not the same behaviour that you described unfortunatly.
    Mine won't answer and they won't even ring. On my Debian 3CX 15.5 most of my phones behave if they were not existing in the group.
    All of them work fine in Call Queues though.
  9. leejor
    10,835
    294
  10. chris.moses@ekriley.com
    Jul 7, 2016
    9
    Auto answer is disabled on all phones. Ring groups work correctly if they are the first link in the chain as well (we have several DIDs that hit a ring group first before being escalated to a larger ring group).
  11. leejor
    10,835
    294
    For 3CX to "see" an answer, it must be receiving a SIP message back from that set. So... some combination of events/options seems to be incorrectly triggering that.
  12. chris.moses@ekriley.com
    Jul 7, 2016
    9
    Wouldn't the handset show the call as answered if that were the case?
  13. SECOIT GmbH
    Apr 3, 2017
    66
    19
    Hey Chris,
    Sorry for the confusion, I found the error in the meantime which in fact was caused by a rather tall human sitting at my PC all day. :)
    Anyway, to your issue, I set up the exact same scenario (only using different numbers) but it works exactly as extended. I can't reproduce the error. All working fine here.
  14. chris.moses@ekriley.com
    Jul 7, 2016
    9
    Well it looks like I found a fix, but it's stupid. I have to go into each existing ring group and remove one extension. Save. Go into the same ring group and add that extension back in. Save. Then calls proceed normally as expected. Definitely seems like some kind of a bug or a change in how the internal database treats ring groups with the latest version. Hopefully this helps someone else who experiences the same issue.
  15. chris.moses@ekriley.com
    Jul 7, 2016
    9
    Actually that fixes SOME ring groups... Others are still having the problem. This makes no sense...
  16. chris.moses@ekriley.com
    Jul 7, 2016
    9
    OK, I've actually tracked it down now. It's related to the iOS 3CX client...
    *If* a user in a ring group that is forwarded to, has the iOS 3CX client installed on their iPhone, the system THINKS that they have connected to the call when it hits the ring group. This is the case even if their iPhone still shows the "swipe to accept" screen (which does not go away).
    Here's the thread in the iOS forum:
    https://www.3cx.com/community/threads/ring-group-fails-with-extension-using-iphone-client.49347/
    #16 chris.moses@ekriley.com, Jul 14, 2017
