Calls made via 3CX Call Control API, no outbound caller ID
Discussion in '3CX Phone System - General' started by dniesen, Sep 21, 2015.
  1. dniesen
    Sep 21, 2015
    We purchased a 3rd-party add-on to dispatch voicemails to our after-hours on-call folks and it works very slick. The one downfall so far is that the outbound call made by the software shows up as an unknown caller by the recipient. We only have a single SIP trunk which does have our caller ID specified so I'm not sure why this is happening.
    I checked with the developer who stated that it uses the 3CX Call Control API which does not dictate the caller id and that the trunk should be what dictates that.
    Has anybody run into this?
    We're using 3CX v12.5 Standard, the third-party app is VOIPToys On Call Manager Standard.
    Thanks!
  2. millsey
    millsey New Member
    Dec 21, 2011
    190
    Re: Calls made via 3CX Call Control API, no outbound caller
    We did something similar and we noted that the outbound ID is accepted by the API if the field has a space, but that stopped the outbound caller ID working for us, make sure you don't have and spaces in any config for this program (and possibly any non numeric character might cause this).
    Millsey
