Calls not ending
Discussion in '3CX Phone System - General' started by jwguy, Feb 22, 2008.
  1. jwguy
    Feb 22, 2008
    I am using the grandstream 4104 with and headsets. I seems that when you dial a wrong or bad number the call does not end. I It shows the extension as "calling" then we have to restart the service and the gateway. Sometimes after several minuets it will start working but usally not.
    08:33:42.570 FaxCfg::updateContact [CM504008]: Fax Service: registered as sip:8888@3CXPhoneSystem with contact sip:8888@192.168.1.53:5100;user=phone
    08:33:42.117 FaxCfg::updateContact [CM504010]: Fax Service: unregistered contact sip:8888:5100;user=phone
    08:23:42.697 FaxCfg::updateContact [CM504008]: Fax Service: registered as sip:8888@3CXPhoneSystem with contact sip:8888@192.168.1.53:5100;user=phone
    08:23:42.167 FaxCfg::updateContact [CM504010]: Fax Service: unregistered contact sip:8888:5100;user=phone
    08:23:27.055 StunClient::process [CM506003]: Resolved SIP external IP:port has changed to (12.219.52.96:64240) on Transport 192.168.1.53:5060
    08:23:26.977 StunClient::eek:nInitTests [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 64.69.76.23:3478 over Transport 192.168.1.53:5060
    08:11:45.445 Call::Terminate [CM503008]: Call(43): Call is terminated
    08:11:45.399 Call::Terminate [CM503008]: Call(43): Call is terminated
    08:11:43.307 LineCfg::getInboundTarget [CM503011]: Inbound office hours' rule for LN:7100 forwards to DN:1000
    08:11:36.641 LineCfg::getInboundTarget [CM503011]: Inbound office hours' rule for LN:7100 forwards to DN:1000
    08:11:36.625 CallCtrl::eek:nLegConnected [CM503007]: Call(43): Device joined: sip:7100@192.168.1.253:5060
    08:11:36.313 CallCtrl::eek:nLegConnected [CM503007]: Call(43): Device joined: sip:
    08:11:36.313 LineCfg::getInboundTarget [CM503011]: Inbound office hours' rule for LN:7100 forwards to DN:1000
    08:11:36.282 CallCtrl::eek:nRerouteReq [CM503005]: Call(43): Forwarding: IVR:RecordMessage@[Dev]
    08:11:27.977 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(43): Calling: Ext:1000@[Dev:sip:1000@192.168.1.55:5070;rinstance=5a3fc63fb76b9365]
    08:11:27.977 Line::printEndpointInfo [CM505002]: Gateway:[pctgateway] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Grandstream GXW4104 (HW 0001, Ch:4) 1.0.0.55] Transport: [sip:192.168.1.53:5060]
    08:11:27.977 LineCfg::getInboundTarget [CM503011]: Inbound office hours' rule for LN:7100 forwards to DN:1000
    08:11:27.945 CallCtrl::eek:nIncomingCall [CM503001]: Call(43): Incoming call from 2178472069@(Ln.7100@pctgateway) to [sip:1000@192.168.1.53:5060]
    08:11:27.930 LineCfg::getInboundTarget [CM503011]: Inbound office hours' rule for LN:7100 forwards to DN:1000
    08:11:01.937 Call::Terminate [CM503008]: Call(42): Call is terminated
    08:11:01.891 Call::Terminate [CM503008]: Call(42): Call is terminated
    08:10:59.767 LineCfg::getInboundTarget [CM503011]: Inbound office hours' rule for LN:7100 forwards to DN:1000
    08:10:51.494 LineCfg::getInboundTarget [CM503011]: Inbound office hours' rule for LN:7100 forwards to DN:1000
    08:10:51.478 CallCtrl::eek:nLegConnected [CM503007]: Call(42): Device joined: sip:7100@192.168.1.253:5060
    08:10:51.150 CallCtrl::eek:nLegConnected [CM503007]: Call(42): Device joined: sip:
    08:10:51.150 LineCfg::getInboundTarget [CM503011]: Inbound office hours' rule for LN:7100 forwards to DN:1000
    08:10:51.119 CallCtrl::eek:nRerouteReq [CM503005]: Call(42): Forwarding: IVR:RecordMessage@[Dev]
    08:10:43.017 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(42): Calling: Ext:1000@[Dev:sip:1000@192.168.1.55:5070;rinstance=5a3fc63fb76b9365]
    08:10:43.017 Line::printEndpointInfo [CM505002]: Gateway:[pctgateway] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Grandstream GXW4104 (HW 0001, Ch:4) 1.0.0.55] Transport: [sip:192.168.1.53:5060]
    08:10:43.017 LineCfg::getInboundTarget [CM503011]: Inbound office hours' rule for LN:7100 forwards to DN:1000
    08:10:42.985 CallCtrl::eek:nIncomingCall [CM503001]: Call(42): Incoming call from 3195246099@(Ln.7100@pctgateway) to [sip:1000@192.168.1.53:5060]
    08:10:42.985 LineCfg::getInboundTarget [CM503011]: Inbound office hours' rule for LN:7100 forwards to DN:1000
    08:08:44.060 Call::Terminate [CM503008]: Call(41): Call is terminated
    08:08:44.029 Call::Terminate [CM503008]: Call(41): Call is terminated
    08:08:41.906 LineCfg::getInboundTarget [CM503011]: Inbound office hours' rule for LN:7100 forwards to DN:1000
    08:08:34.256 LineCfg::getInboundTarget [CM503011]: Inbound office hours' rule for LN:7100 forwards to DN:1000
    08:08:34.241 CallCtrl::eek:nLegConnected [CM503007]: Call(41): Device joined: sip:7100@192.168.1.253:5060
    08:08:33.601 CallCtrl::eek:nLegConnected [CM503007]: Call(41): Device joined: sip:
    08:08:33.601 LineCfg::getInboundTarget [CM503011]: Inbound office hours' rule for LN:7100 forwards to DN:1000
    08:08:33.569 CallCtrl::eek:nRerouteReq [CM503005]: Call(41): Forwarding: IVR:RecordMessage@[Dev]
    08:08:25.327 CallCtrl::eek:nSelectRouteReq [CM503004]: Call(41): Calling: Ext:1000@[Dev:sip:1000@192.168.1.55:5070;rinstance=5a3fc63fb76b9365]
    08:08:25.327 Line::printEndpointInfo [CM505002]: Gateway:[pctgateway] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Grandstream GXW4104 (HW 0001, Ch:4) 1.0.0.55] Transport: [sip:192.168.1.53:5060]
    08:08:25.327 LineCfg::getInboundTarget [CM503011]: Inbound office hours' rule for LN:7100 forwards to DN:1000
    08:08:25.296 CallCtrl::eek:nIncomingCall [CM503001]: Call(41): Incoming call from 3197950199@(Ln.7100@pctgateway) to [sip:1000@192.168.1.53:5060]
    08:08:25.280 LineCfg::getInboundTarget [CM503011]: Inbound office hours' rule for LN:7100 forwards to DN:1000
    08:03:27.935 StunClient::process [CM506003]: Resolved SIP external IP:port has changed to (12.219.52.96:64227) on Transport 192.168.1.53:5060
    08:03:27.857 StunClient::eek:nInitTests [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 64.69.76.23:3478 over Transport 192.168.1.53:5060
    07:43:43.443 FaxCfg::updateContact [CM504008]: Fax Service: registered as sip:8888@3CXPhoneSystem with contact sip:8888@192.168.1.53:5100;user=phone
    07:43:43.068 FaxCfg::updateContact [CM504010]: Fax Service: unregistered contact sip:8888:5100;user=phone
    07:43:28.410 StunClient::process [CM506003]: Resolved SIP external IP:port has changed to (12.219.52.96:64207) on Transport 192.168.1.53:5060
    07:43:28.332 StunClient::eek:nInitTests [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 64.69.76.23:3478 over Transport 192.168.1.53:5060
    07:33:43.665 FaxCfg::updateContact [CM504008]: Fax Service: registered as sip:8888@3CXPhoneSystem with contact sip:8888@192.168.1.53:5100;user=phone
    07:33:43.118 FaxCfg::updateContact [CM504010]: Fax Service: unregistered contact sip:8888:5100;user=phone
    07:23:44.105 FaxCfg::updateContact [CM504008]: Fax Service: registered as sip:8888@3CXPhoneSystem with contact sip:8888@192.168.1.53:5100;user=phone
    07:23:43.777 FaxCfg::updateContact [CM504010]: Fax Service: unregistered contact sip:8888:5100;user=phone
    07:23:29.368 StunClient::process [CM506003]: Resolved SIP external IP:port has changed to (12.219.52.96:64190) on Transport 192.168.1.53:5060
    07:23:29.290 StunClient::eek:nInitTests [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 64.69.76.23:3478 over Transport 192.168.1.53:5060
    07:03:30.279 StunClient::process [CM506003]: Resolved SIP external IP:port has changed to (12.219.52.96:64177) on Transport 192.168.1.53:5060
    07:03:30.201 StunClient::eek:nInitTests [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 64.69.76.23:3478 over Transport 192.168.1.53:5060
    06:43:30.957 StunClient::process [CM506003]: Resolved SIP external IP:port has changed to (12.219.52.96:64154) on Transport 192.168.1.53:5060
    06:43:30.878 StunClient::eek:nInitTests [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 64.69.76.23:3478 over Transport 192.168.1.53:5060
    06:23:31.712 StunClient::process [CM506003]: Resolved SIP external IP:port has changed to (12.219.52.96:64133) on Transport 192.168.1.53:5060
    06:23:31.634 StunClient::eek:nInitTests [CM506001]: STUN request to resolve SIP external IP:port mapping is sent to STUN server 64.69.76.23:3478 over Transport 192.168.1.53:5060
  2. jwguy
    Feb 22, 2008
    Also I am running the latest version of software. Version5.1.4128.0
