Solved Calls not going to VM - continuously rings phone.
Discussion in '3CX Phone System - General' started by tparker, Mar 9, 2018.
  1. tparker
    Dec 29, 2017
    9
    We have a client who we just recently setup a 3CX 15.5 server for. Most everything is working as intended, however, recently there has been a problem of when using internel transferring, the phone will just continue to ring and not go to voicemail.
    VM is enabled on all extensions. We updated the firmware on all of the phones last night, as updating the firmware on one phone seemed to correct the issue, but after the FW upgrade, the issue still persists, even on the one extension that was working after the first upgrade.
    Any Ideas?
  2. tparker
    Dec 29, 2017
    9
    Please disregard this, The client was not hitting 'transfer' a second time after dialing the extension.
  3. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,443
    282
    Glad the issue has been resolved and thank you for updating the post with the solution.
