Calls quality - chopped voice
Discussion in '3CX Phone System - General' started by RobLloyd, Mar 9, 2008.
  1. RobLloyd
    RobLloyd Member
    Oct 13, 2006
    481
    To start with, you using the free version - you can't use G729 at all, not even on the phones themselves. Change everything to g711 and start there.
    Check out http://myvoipspeed.visualware.com/ and see what you get for internet quality. Your specs are fine but if your line is bad then your calls will be bad.
    Choppy voice can come from several areas - bad routers, too much equipment in the way etc. What's your config?
  2. paragondie
    Jun 25, 2007
    52
    Look at your silence suppression on your gateway and your phones. We turned these off and it helped with this problem.
  3. Ryandc
    Aug 13, 2007
    70
    On my to-do list would be the following:
    1) Upgrade to the latest SPA-922 firmware. They ship with 4.1. Right now, 5.2.5 is the latest available.
    2) Internal vs. external calls. Is it choppy on calls between extensions? Or only on calls going outside? If it's only on calls going outside, check the following:
    a) jitter level (set it higher)
    b) codecs-- make sure you're using ones your VOIP provider supports. Try all of these, in order from most bandwidth to least. Codecs that compress more introduce a bit of latency but use less bandwidth.
    c) Make sure "bind to media server" isn't checked for ANYTHING. That'll hash things up unless it's absolutely necessary.
    3) If it's happening on both internal and external callls:
    a) check server QOS
    b) check router QOS (if it supports it)
    That's all I can recommend. I run SPA-922s here, and they're perfectly clear.
    -Ryan
  4. code937
    Jul 27, 2007
    6
    I also have a choppy line when calling other people with a low volume. I've got a budge tone 102 and in the config silence sup is switched off, does anyone know the best codecs to use in order of 1 - 8 on the phone and is there anything i can do on the 3cx system to stop choppyness.
    Thanks!
