Calls Rejected - Internal
Discussion in '3CX Phone System - General' started by carlos.asj1, Aug 1, 2008.
  1. carlos.asj1
    Aug 1, 2008
    Hy, this is my first time using the 3CX Phone System.
    I set up a lab environment using Virtual PC 2007 + Windows Server 2003. The installation was just fine, and in the other two virtual machines (Windows XP) the 3CX Voip Client it's registered on the server.
    Than I create two extensions 1000 and 1001 (4 digits), but when I try to call the other virtual machine, I got Forbidden!
    This is the server log:
    18:59:13.640 Call::Terminate [CM503008]: Call(1): Call is terminated
    18:59:13.640 CallCtrl::eek:nIncomingCall [CM502001]: Source info: From: 1; To: "3CXPhone"[sip:1000@ocs-sip.contoso.local:5060];tag=b200353c[sip:1001@ocs-sip.contoso.local:5060]
    18:59:13.640 CallCtrl::eek:nIncomingCall [CM503013]: Call(1): Incoming call rejected, caller is unknown; msg=SipReq: INVITE 1001@ocs-sip.contoso.local:5060 tid=5c3d085bbf5f5529 cseq=INVITE contact=1000@192.168.0.20:5070 / 2 from(wire)
    18:59:12.949 evt::CheckIfAuthIsRequired::not_handled [CM500002]: Unidentified incoming call. Review INVITE and adjust source identification:
    INVITE sip:1001@ocs-sip.contoso.local:5060 SIP/2.0
    Via: SIP/2.0/UDP 192.168.0.20:5070;branch=z9hG4bK-d8754z-4e4a255b6e67870f-1---d8754z-;rport=5070
    Max-Forwards: 70
    Contact: [sip:1000@192.168.0.20:5070]
    To: [sip:1001@ocs-sip.contoso.local:5060]
    From: "3CXPhone"[sip:1000@ocs-sip.contoso.local:5060];tag=b200353c
    Call-ID: YTg5MWM1YWU4YTU1OTNhMWNhNTNlZmM2YTNkNDU3ODA.
    CSeq: 1 INVITE
    Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REGISTER, SUBSCRIBE, NOTIFY, REFER, INFO
    Supported: replaces
    User-Agent: 3CX Phone 6.0.727.0
    Content-Length: 0
    18:59:12.949 evt::CheckIfAuthIsRequired::not_handled [CM302001]: Authorization system can not identify source of: SipReq: INVITE 1001@ocs-sip.contoso.local:5060 tid=4e4a255b6e67870f cseq=INVITE contact=1000@192.168.0.20:5070 / 1 from(wire)
    I'm a newbie at this .. so any help will great.
    I don't set lines or outbound rules, since the virtual machines can't connect to internet and I'm trying to make a internal call.
  2. carlos.asj1
    Aug 1, 2008
    Problem solved !!
    I've configure the FQDN of the SIP server on the client. I don't know why, when I put only the IP, it work!
