star1
- Joined
- Apr 7, 2010
- Messages
- 43
- Reaction score
- 0
We're testing the Android v12 client and are experiencing a strange problem. When the android client is running, incoming calls ring on the client and the associated Snom desk phone as expected. When the Android client is exited, incoming calls ring for a quick second on the desk phone and then go straight to voicemail. When the android phone is powered off, the calls ring on the Snom desk phone normally.
Setup Info:
[*] 3CX v12 SP1 configured with GCM Push notifications.
[*] Extension has push notifications enabled.
[*] Android client configured via auto-provisioned.
[*] Presence is set to Available
It seems that what's happening is when the android receives the notification of an incoming call and there's no client running, the server is sending the call to voicemail. If the android is off and no notification can be received by the android, the call continues as normal.
Am I missing something in the configuration that is causing this to happen? Is there something I should be doing differently?
Thanks for your help.
Eric
Setup Info:
Eric
