- Joined
- Aug 3, 2009
- Messages
- 12
- Reaction score
- 0
Hello, this is my first post.
I have been playing with the 3CX software for a short while now. I have aquired some CISCO kit, and have managed to convert it from SCCP to SIP. I have set up a few extensions within 3CX. All appears to be okay, however whe i dial a phone number, nothing happens. When i check the Server Activity Log, it all seems okay but fails on Reason: No Answer, but nothing had rang. All help is much appreicated. I hope there is enough information in the activity log to help.
Many Thanks,
Chris Goodman
22:30:41.968 [CM504008]: Fax Service: registered as sip:[email protected] with contact sip:[email protected]:5060;user=phone;transport=udp
22:30:41.859 [CM504001]: Ext.4000: new contact is registered. Contact(s): [sip:[email protected]:5060;user=phone;transport=udp/4000]
22:30:36.203 [CM503008]: Call(36): Call is terminated
22:30:36.187 [CM503015]: Call(36): Attempt to reach <sip:[email protected]> failed. Reason: No Answer
22:30:36.187 [CM503003]: Call(36): Call to sip:[email protected]:5060 has failed; Cause: 408 Request Timeout; internal
22:30:32.031 [CM504008]: Fax Service: registered as sip:[email protected]:5060 with contact sip:[email protected]:5100;user=phone
22:30:04.078 [CM503024]: Call(36): Calling Ext:Ext.4000@[Dev:sip:[email protected]:5060;user=phone;transport=udp]
22:30:04.000 [CM503004]: Call(36): Route 1: Ext:Ext.4000@[Dev:sip:[email protected]:5060;user=phone;transport=udp]
22:30:04.000 [CM503010]: Making route(s) to <sip:[email protected]>
22:30:03.968 [CM505001]: Ext.1500: Device info: Device Identified: [Man: Cisco;Mod: 7940;Rev: General] Capabilities:[reinvite, replaces, unable-no-sdp, no-recvonly] UserAgent: [Cisco-CP7940G/8.0] Transport: [sip:192.168.1.5:5060]
22:30:03.921 [CM503001]: Call(36): Incoming call from Ext.1500 to <sip:[email protected]>
22:30:00.656 [CM503008]: Call(35): Call is terminated
22:30:00.125 [CM503024]: Call(35): Calling Ext:Ext.4000@[Dev:sip:[email protected]:5060;user=phone;transport=udp]
22:30:00.109 [CM503004]: Call(35): Route 1: Ext:Ext.4000@[Dev:sip:[email protected]:5060;user=phone;transport=udp]
22:30:00.109 [CM503010]: Making route(s) to <sip:[email protected]>
22:30:00.093 [CM505001]: Ext.1000: Device info: Device Identified: [Man: Cisco;Mod: 7940;Rev: General] Capabilities:[reinvite, replaces, unable-no-sdp, no-recvonly] UserAgent: [Cisco-CP7940G/8.0] Transport: [sip:192.168.1.5:5060]
22:30:00.046 [CM503001]: Call(35): Incoming call from Ext.1000 to <sip:[email protected]>
22:29:55.281 [CM503008]: Call(34): Call is terminated
22:29:50.406 [CM503024]: Call(34): Calling Ext:Ext.1000@[Dev:sip:[email protected]:5061;transport=udp]
22:29:50.343 [CM503004]: Call(34): Route 1: Ext:Ext.1000@[Dev:sip:[email protected]:5061;transport=udp]
22:29:50.343 [CM503010]: Making route(s) to <sip:[email protected]>
22:29:50.328 [CM505001]: Ext.1500: Device info: Device Identified: [Man: Cisco;Mod: 7940;Rev: General] Capabilities:[reinvite, replaces, unable-no-sdp, no-recvonly] UserAgent: [Cisco-CP7940G/8.0] Transport: [sip:192.168.1.5:5060]
22:29:50.296 [CM503001]: Call(34): Incoming call from Ext.1500 to <sip:[email protected]>
22:29:40.562 [CM503008]: Call(33): Call is terminated
22:29:26.453 [CM503024]: Call(33): Calling Ext:Ext.4000@[Dev:sip:[email protected]:5060;user=phone;transport=udp]
22:29:26.390 [CM503004]: Call(33): Route 1: Ext:Ext.4000@[Dev:sip:[email protected]:5060;user=phone;transport=udp]
22:29:26.390 [CM503010]: Making route(s) to <sip:[email protected]>
22:29:26.390 [CM505001]: Ext.1000: Device info: Device Identified: [Man: Cisco;Mod: 7940;Rev: General] Capabilities:[reinvite, replaces, unable-no-sdp, no-recvonly] UserAgent: [Cisco-CP7940G/8.0] Transport: [sip:192.168.1.5:5060]
22:29:26.343 [CM503001]: Call(33): Incoming call from Ext.1000 to <sip:[email protected]>
22:29:16.265 [CM503008]: Call(32): Call is terminated
22:28:56.984 [CM503024]: Call(32): Calling Ext:Ext.1000@[Dev:sip:[email protected]:5061;transport=udp]
22:28:56.968 [CM503004]: Call(32): Route 1: Ext:Ext.1000@[Dev:sip:[email protected]:5061;transport=udp]
22:28:56.968 [CM503010]: Making route(s) to <sip:[email protected];user=phone>
22:28:56.968 [CM505001]: Ext.4000: Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [Cisco ATA 186 v3.1.0 atasip (040211A)] Transport: [sip:192.168.1.5:5060]
22:28:56.937 [CM503001]: Call(32): Incoming call from Ext.4000 to <sip:[email protected];user=phone>
22:25:31.843 [CM504008]: Fax Service: registered as sip:[email protected]:5060 with contact sip:[email protected]:5100;user=phone
22:25:23.828 [CM504001]: Ext.1500: new contact is registered. Contact(s): [sip:[email protected]:5061;transport=udp/1500]
22:25:23.546 [CM504001]: Ext.1000: new contact is registered. Contact(s): [sip:[email protected]:5061;transport=udp/1000]
22:25:23.453 [CM504001]: Ext.1000: new contact is registered. Contact(s): [sip:[email protected]:5061;transport=udp/1000]
22:20:31.593 [CM504008]: Fax Service: registered as sip:[email protected]:5060 with contact sip:[email protected]:5100;user=phone
22:15:31.406 [CM504008]: Fax Service: registered as sip:[email protected]:5060 with contact sip:[email protected]:5100;user=phone
22:15:24.546 [CM506001]: STUN request to resolve SIP external IPort mapping is sent to STUN server 75.101.138.128:3478 over Transport 192.168.1.5:5060
22:10:31.187 [CM504008]: Fax Service: registered as sip:[email protected]:5060 with contact sip:[email protected]:5100;user=phone
22:05:31.000 [CM504008]: Fax Service: registered as sip:[email protected]:5060 with contact sip:[email protected]:5100;user=phone
22:05:01.453 [CM504008]: Fax Service: registered as sip:[email protected] with contact sip:[email protected]:5060;user=phone;transport=udp
22:05:01.375 [CM504001]: Ext.4000: new contact is registered. Contact(s): [sip:[email protected]:5060;user=phone;transport=udp/4000]
22:00:30.781 [CM504008]: Fax Service: registered as sip:[email protected]:5060 with contact sip:[email protected]:5100;user=phone
22:00:05.171 [CM503008]: Call(31): Call is terminated
22:00:05.156 [CM503015]: Call(31): Attempt to reach <sip:[email protected]> failed. Reason: No Answer
22:00:05.156 [CM503003]: Call(31): Call to sip:[email protected]:5060 has failed; Cause: 408 Request Timeout; internal
21:59:33.046 [CM503024]: Call(31): Calling Ext:Ext.4000@[Dev:sip:[email protected]:5060;user=phone;transport=udp]
21:59:33.031 [CM503004]: Call(31): Route 1: Ext:Ext.4000@[Dev:sip:[email protected]:5060;user=phone;transport=udp]
21:59:33.031 [CM503010]: Making route(s) to <sip:[email protected]>
21:59:33.031 [CM505001]: Ext.1000: Device info: Device Identified: [Man: Cisco;Mod: 7940;Rev: General] Capabilities:[reinvite, replaces, unable-no-sdp, no-recvonly] UserAgent: [Cisco-CP7940G/8.0] Transport: [sip:192.168.1.5:5060]
21:59:33.000 [CM503001]: Call(31): Incoming call from Ext.1000 to <sip:[email protected]>
21:57:25.953 [CM503008]: Call(30): Call is terminated
21:57:25.937 [CM503015]: Call(30): Attempt to reach <sip:[email protected]> failed. Reason: No Answer
21:57:25.921 [CM503003]: Call(30): Call to sip:[email protected]:5060 has failed; Cause: 408 Request Timeout; internal
21:56:53.843 [CM503024]: Call(30): Calling Ext:Ext.4000@[Dev:sip:[email protected]:5060;user=phone;transport=udp]
21:56:53.828 [CM503004]: Call(30): Route 1: Ext:Ext.4000@[Dev:sip:[email protected]:5060;user=phone;transport=udp]
21:56:53.796 [CM503010]: Making route(s) to <sip:[email protected]>
21:56:53.796 [CM505001]: Ext.1000: Device info: Device Identified: [Man: Cisco;Mod: 7940;Rev: General] Capabilities:[reinvite, replaces, unable-no-sdp, no-recvonly] UserAgent: [Cisco-CP7940G/8.0] Transport: [sip:192.168.1.5:5060]
21:56:53.765 [CM503001]: Call(30): Incoming call from Ext.1000 to <sip:[email protected]>
21:55:30.578 [CM504008]: Fax Service: registered as sip:[email protected]:5060 with contact sip:[email protected]:5100;user=phone
21:55:28.187 [CM504001]: Ext.1500: new contact is registered. Contact(s): [sip:[email protected]:5061;transport=udp/1500]
21:55:27.859 [CM504001]: Ext.1000: new contact is registered. Contact(s): [sip:[email protected]:5061;transport=udp/1000]
21:55:27.781 [CM504001]: Ext.1000: new contact is registered. Contact(s): [sip:[email protected]:5061;transport=udp/1000]
21:55:24.312 [CM506001]: STUN request to resolve SIP external IPort mapping is sent to STUN server 75.101.138.128:3478 over Transport 192.168.1.5:5060
21:52:29.359 [CM503008]: Call(29): Call is terminated
21:52:24.312 [CM503024]: Call(29): Calling Ext:Ext.4000@[Dev:sip:[email protected]:5060;user=phone;transport=udp]
21:52:24.265 [CM503004]: Call(29): Route 1: Ext:Ext.4000@[Dev:sip:[email protected]:5060;user=phone;transport=udp]
21:52:24.265 [CM503010]: Making route(s) to <sip:[email protected]>
21:52:24.250 [CM505001]: Ext.1000: Device info: Device Identified: [Man: Cisco;Mod: 7940;Rev: General] Capabilities:[reinvite, replaces, unable-no-sdp, no-recvonly] UserAgent: [Cisco-CP7940G/8.0] Transport: [sip:192.168.1.5:5060]
21:52:24.218 [CM503001]: Call(29): Incoming call from Ext.1000 to <sip:[email protected]>
21:50:30.375 [CM504008]: Fax Service: registered as sip:[email protected]:5060 with contact sip:[email protected]:5100;user=phone
21:45:30.187 [CM504008]: Fax Service: registered as sip:[email protected]:5060 with contact sip:[email protected]:5100;user=phone
21:43:46.593 [CM503008]: Call(28): Call is terminated
21:43:37.453 [CM503024]: Call(28): Calling Ext:Ext.4000@[Dev:sip:[email protected]:5060;user=phone;transport=udp]
21:43:37.437 [CM503004]: Call(28): Route 1: Ext:Ext.4000@[Dev:sip:[email protected]:5060;user=phone;transport=udp]
21:43:37.390 [CM503010]: Making route(s) to <sip:[email protected]>
21:43:37.375 [CM505001]: Ext.1000: Device info: Device Identified: [Man: Cisco;Mod: 7940;Rev: General] Capabilities:[reinvite, replaces, unable-no-sdp, no-recvonly] UserAgent: [Cisco-CP7940G/8.0] Transport: [sip:192.168.1.5:5060]
21:43:37.343 [CM503001]: Call(28): Incoming call from Ext.1000 to <sip:[email protected]>
21:43:34.593 [CM503008]: Call(27): Call is terminated
21:43:22.906 [CM503024]: Call(27): Calling Ext:Ext.4000@[Dev:sip:[email protected]:5060;user=phone;transport=udp]
21:43:22.890 [CM503004]: Call(27): Route 1: Ext:Ext.4000@[Dev:sip:[email protected]:5060;user=phone;transport=udp]
21:43:22.859 [CM503010]: Making route(s) to <sip:[email protected]>
21:43:22.859 [CM505001]: Ext.1000: Device info: Device Identified: [Man: Cisco;Mod: 7940;Rev: General] Capabilities:[reinvite, replaces, unable-no-sdp, no-recvonly] UserAgent: [Cisco-CP7940G/8.0] Transport: [sip:192.168.1.5:5060]
21:43:22.828 [CM503001]: Call(27): Incoming call from Ext.1000 to <sip:[email protected]>
21:43:11.937 [CM503008]: Call(25): Call is terminated
21:43:11.906 [CM503015]: Call(25): Attempt to reach <sip:[email protected];user=phone> failed. Reason: No Answer
21:43:11.906 [CM503003]: Call(25): Call to sip:[email protected] has failed; Cause: 408 Request Timeout; internal
21:43:05.859 [CM503008]: Call(26): Call is terminated
21:43:05.859 [CM503015]: Call(26): Attempt to reach <sip:[email protected]> failed. Reason: Busy
21:43:05.843 [CM503015]: Call(26): Attempt to reach <sip:[email protected]> failed. Reason: Busy
21:43:05.843 [CM503014]: Call(26): No known route to target: <sip:[email protected]>
21:43:05.843 [CM503010]: Making route(s) to <sip:[email protected]>
21:43:05.843 [CM505001]: Ext.1000: Device info: Device Identified: [Man: Cisco;Mod: 7940;Rev: General] Capabilities:[reinvite, replaces, unable-no-sdp, no-recvonly] UserAgent: [Cisco-CP7940G/8.0] Transport: [sip:192.168.1.5:5060]
21:43:05.812 [CM503001]: Call(26): Incoming call from Ext.1000 to <sip:[email protected]>
21:42:39.843 [CM503024]: Call(25): Calling Ext:Ext.1000@[Dev:sip:[email protected]:5061;transport=udp]
Many Thanks,
Chris Goodman
