Calls to Mobiles and 1300 numbers on Mynetfone
Discussion in '3CX Phone System - General' started by pjulian, Mar 11, 2008.
  1. pjulian
    Mar 11, 2008
    Hi guys, we are trialling the 3CX system and love the features, however we are trying to get it to work successfully with our VOIP provider which is Mynetfone in Australia. We have been using them for about 18 months with a Linksys 3102 ATA and all has been fine, but no matter what I do I can't get reliable consistent connections to them from the 3CX box. I have been doing all testing with the 3CX softphone to rule out any other phone or ATA related issues.
    I can get it working using the default generic SIP provider settings and can make local calls without issue usually, but when I try and dial a mobile starting with 04XXXXXXXX or a 1300XXXXXX number it just rings. Sometimes when calling a landline it does the same thing, but not always. In the logs I get a 503 Service Unavailable error and it just keeps cycling through that as shown below and the phone just rings on the softphone, but the actual phone you are ringing never rings once.
    23:21:37.812 Call::Terminate [CM503008]: Call(28): Call is terminated
    23:21:33.375 Line::printEndpointInfo [CM505003]: Provider:[MNF] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [ENS2.5.31] Transport: [sip:xxxxxxxxx:5060]
    23:21:33.375 CallCtrl::eek:nAnsweredCall [CM503002]: Call(28): Alerting sip:XXXXXXXX@sip.mynetfone.com.au:5060
    23:21:32.656 MediaServerReporting::SetRemoteParty [MS210002] C:28.4:Offer provided. Connection(transcoding mode): xxxxxxxx:9004(9005)
    23:21:32.593 CallLeg::eek:nFailure [CM503003]: Call(28): Call to sip:04xxxxxxxx@sip10.mynetfone.com.au:5060 has failed; Cause: 503 Service Unavailable; from IP:125.213.160.81:5060
    23:21:21.265 Line::printEndpointInfo [CM505003]: Provider:[MNF] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [ENS2.5.31] Transport: [sip:xxxxxx:5060]
    23:21:21.265 CallCtrl::eek:nAnsweredCall [CM503002]: Call(28): Alerting sip:xxxxxxx@sip.mynetfone.com.au:5060
    23:21:20.562 MediaServerReporting::SetRemoteParty [MS210002] C:28.3:Offer provided. Connection(transcoding mode): xxxxxxxx:9002(9003)
    23:21:20.515 CallLeg::eek:nFailure [CM503003]: Call(28): Call to sip:04xxxxxxxx@sip10.mynetfone.com.au:5060 has failed; Cause: 503 Service Unavailable; from IP:125.213.160.81:5060
    23:21:09.578 Line::printEndpointInfo [CM505003]: Provider:[MNF] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [ENS2.5.31] Transport: [sip:xxxxxxxx:5060]
    23:21:09.578 CallCtrl::eek:nAnsweredCall [CM503002]: Call(28): Alerting sip:xxxxxxxx@sip.mynetfone.com.au:5060
    23:21:08.859 MediaServerReporting::SetRemoteParty [MS210002] C:28.2:Offer provided. Connection(transcoding mode): xxxxxxxxx:9000(9001)
    I have tried changing codecs, changing support re-invite settings, trolling for hours through this forum and others trying to find some answers but keep coming up blank. I have contacted Mynetfone and they say they don't support 3CX, so they aren't really any help.
    The system is running on a VMware box behind a linux based firewall with masquerading setup. I have also port forwarded 9000-9015 and 5060 to the internal IP of the 3CX box.
    I would really appreciate any suggestions as I am keen to get this working as I feel it could be a great solution for us to offer our customers.
    Paul
  2. landfiets
    landfiets New Member
    Jul 17, 2007
    243
    When you dial directly from a softphone with the same provider, everything is fine? Try it on X-lite registering directly in your providers system. When everything works it is your 3cx configuring, when you have the same problem we have to look for something else. It can be a NAT problem, but test it like this.
  3. pjulian
    Mar 11, 2008
    Yes everything is fine when connecting to the provider with a softphone or the Linksys. When you say X-lite, you mean 3CX lite ? If so, that's what I am testing with. It is a strange problem, I really would have though that NAT wouldn't make a difference to a certain range of numbers failing, but am happy to be proved wrong :)
    I am keen to get this working, there has to be a logical explanation somewhere. thanks for your help.
    Regards
    Paul
  4. BJReplay
    BJReplay New Member
    Oct 31, 2007
    133
    My guess is you've got an outbound rule set up that is stripping the zero from your 04... numbers?
    I've using MyNetFone (two whirlpoolsaver, one neosaver), and have no probs at all for outbound or inbound calls. We're only making around 20 calls a day, but they're all working.
    A 503 from MyNetFone indicates that the number you're dialling is not available - probably because it isn't a valid number. You've xxxxx'd the numbers from your log - as I'd do if I was posting a log - but double check that the xxxxx@sip10 is correct.
