Calls to queue are disconnected
Discussion in '3CX Phone System - General' started by jim@itstod.se, Jul 19, 2011.
  1. jim@itstod.se
    jim@itstod.se New Member
    Apr 7, 2008
    100
    We have two customers with the same setup (3cx v 9 and the same VoIP provider)
    Calls to their main number are set to a queue with x number of extensions.
    In company A this works just fine but for company B all calls are disconnected as soon as the queue "answers" the call.
    The only thing I can find in the log is "No RTP packets transmitted".
    There is one difference I can think of: A has a static IP address whilst B has a dynamic IP and use STUN.
    If I use a ring group in B it works but if there is no answer then the call must go to another queue and then it will fail again, same as when I set it to "answer first".
  2. davidbenwell
    davidbenwell Active Member
    Apr 27, 2010
    704
    could you post the logs from 3CX when this happens so we can see.
  3. jim@itstod.se
    Apr 7, 2008
    100
    16:49:53.477 Currently active calls [none]
    16:49:40.571 [MS105000] C:16.2: No RTP packets were received:remoteAddr=127.0.0.1:32016,extAddr=0.0.0.0:0,localAddr=127.0.0.1:7036
    16:49:40.289 [MS105000] C:16.1: No RTP packets were received:remoteAddr=xxx.xxx.xxx.xxx:4060,extAddr=yyy.yyy.yyy.yyy:9012,localAddr=yyy.yyy.yyy.yyy:9012
    16:49:39.117 [CM503008]: Call(16): Call is terminated
    16:49:39.102 Session 24669 of leg C:16.1 is confirmed
    16:49:39.008 [CM503007]: Call(16): Device joined: sip:806@127.0.0.1:5488
    16:49:38.992 [CM503007]: Call(16): Device joined: sip:scand.spinbox.se@sip.gotanet.se:5060
    16:49:38.992 [MS210005] C:16.1:Answer provided. Connection(proxy mode):yyy.yyy.yyy.yyy:9012(9013)
    16:49:38.977 [MS210001] C:16.2:Answer received. RTP connection[unsecure]: 127.0.0.1:32016(32017)
    16:49:38.977 Remote SDP is set for legC:16.2
    16:49:38.961 [CM505001]: Ext.806: Device info: Device Identified: [Man: 3CX Ltd.;Mod: 3CX Queue;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX Queue Manager (q=806)] PBX contact: [sip:806@127.0.0.1:5060]
    16:49:38.961 [CM503002]: Call(16): Alerting sip:806@127.0.0.1:5488
    16:49:38.774 [CM503025]: Call(16): Calling Ext:Ext.806@[Dev:sip:806@127.0.0.1:5488]
    16:49:38.758 [MS210004] C:16.2:Offer provided. Connection(proxy mode): 127.0.0.1:7036(7037)
    16:49:38.727 [MS210000] C:16.1:Offer received. RTP connection: xxx.xxx.xxx.xxx:4060(4061)
    16:49:38.727 [CM503004]: Call(16): Route 1: Ext:Ext.806@[Dev:sip:806@127.0.0.1:5488]
    16:49:38.727 [CM503010]: Making route(s) to <sip:806@192.168.0.10:5060>
    16:49:38.711 Remote SDP is set for legC:16.1
    16:49:38.711 [CM505003]: Provider:[Size] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [LEICA-1.8.32.1-RC1] PBX contact: [sip:scand.spinbox.se@90.227.103.77:5060]
    16:49:38.711 [CM503001]: Call(16): Incoming call from 0500789306@(Ln.10000@Size) to <sip:806@192.168.0.10:5060>
    16:49:38.664 [CM503012]: Inbound any hours rule (Huvudnummer) for 10000 forwards to DN:806
    16:49:38.664 Looking for inbound target: called=0512650700; caller=0500789306
    16:49:38.649 [CM500002]: Info on incoming INVITE:
    INVITE sip:0512650700@scand.spinbox.se;user=phone SIP/2.0
    Via: SIP/2.0/UDP zzz.zzz.zzz.zzz:5060;branch=z9hG4bK-d8754z-097536527ed22109-1---d8754z-;rport=5060
    Max-Forwards: 70
    Contact: <sip:0500789306@zzz.zzz.zzz.zzz:5060;transport=udp>
    To: "0512650700"<sip:0512650700@scand.spinbox.se;user=phone>
    From: "0500789306"<sip:0500789306@gota.net;user=phone>;tag=1360f315
    Call-ID: YzY3ZDAwZTVkNTIwNGU3N2UyY2Y1NDQ0Y2VmNWUyYWE.
    CSeq: 1 INVITE
    Allow: INVITE, ACK, BYE, CANCEL
    User-Agent: LEICA-1.8.32.1-RC1
    Content-Length: 0
  4. davidbenwell
    Apr 27, 2010
    704
    can you run the 3CX Firewall Checker? and post the output here
  5. jim@itstod.se
    Apr 7, 2008
    100
    3CX Firewall Checker, v1.0. Copyright (C) 3CX Ltd. All rights reserved.
    <09:00:29>: Phase 1, checking servers connection, please wait...
    <09:00:29>: Stun Checker service is reachable. Phase 1 check passed.
    <09:00:29>: Phase 2a, Check Port Forwarding to UDP SIP port, please wait...
    <09:00:30>: UDP SIP Port is set to 5060. Response received correctly with no translation. Phase 2a check passed.
    <09:00:30>: Phase 2b. Check Port Forwarding to TCP SIP port, please wait...
    <09:00:30>: TCP SIP Port is set to 5060. Response received correctly with no translation. Phase 2b check passed.
    <09:00:30>: Phase 3. Check Port Forwarding to TCP Tunnel port, please wait...
    <09:00:30>: TCP TUNNEL Port is set to 5090. Response received correctly with no translation. Phase 3 check passed.
    <09:00:30>: Phase 4. Check Port Forwarding to RTP external port range, please wait...
    <09:00:33>: UDP RTP Port 9000. Response received correctly with no translation. Phase 4-01 check passed.
    <09:00:33>: UDP RTP Port 9001. Response received correctly with no translation. Phase 4-02 check passed.
    <09:00:33>: UDP RTP Port 9002. Response received correctly with no translation. Phase 4-03 check passed.
    <09:00:33>: UDP RTP Port 9003. Response received correctly with no translation. Phase 4-04 check passed.
    <09:00:33>: UDP RTP Port 9004. Response received correctly with no translation. Phase 4-05 check passed.
    <09:00:33>: UDP RTP Port 9005. Response received correctly with no translation. Phase 4-06 check passed.
    <09:00:33>: UDP RTP Port 9006. Response received correctly with no translation. Phase 4-07 check passed.
    <09:00:33>: UDP RTP Port 9007. Response received correctly with no translation. Phase 4-08 check passed.
    <09:00:33>: UDP RTP Port 9008. Response received correctly with no translation. Phase 4-09 check passed.
    <09:00:33>: UDP RTP Port 9009. Response received correctly with no translation. Phase 4-10 check passed.
    <09:00:33>: UDP RTP Port 9010. Response received correctly with no translation. Phase 4-11 check passed.
    <09:00:33>: UDP RTP Port 9011. Response received correctly with no translation. Phase 4-12 check passed.
    <09:00:33>: UDP RTP Port 9012. Response received correctly with no translation. Phase 4-13 check passed.
    <09:00:33>: UDP RTP Port 9013. Response received correctly with no translation. Phase 4-14 check passed.
    <09:00:33>: UDP RTP Port 9014. Response received correctly with no translation. Phase 4-15 check passed.
    <09:00:33>: UDP RTP Port 9015. Response received correctly with no translation. Phase 4-16 check passed.
    Application exit code is 0
  6. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Voip provider MUST be configured as "Support re-Invites"=OFF and "Supports replaces"=OFF
    Please change settings and try again.
  7. jim@itstod.se
    Apr 7, 2008
    100
    Great! that did it!
    Now to the next problem I discovered :S
    It won't play the intro prompts for the queues.I see no error message for "not playing wav:s".
