calls to SIP trunk
Discussion in '3CX Phone System - General' started by lpietro, Oct 28, 2009.
  1. lpietro
    Oct 28, 2009
    I've hust configured the 3CX ( latest release ) to SIP trunk with CCM. Here the address:
    CCM: 10.24.10.102 --> DirectoryNumbers on CCM 2xxxx
    3CX: 10.23.10.200 --> DierctoryNumbers on 3CX 1xxxx
    When i call from CCM --> 3CX all is working fine
    When i call from 3CX --> CCM, i get the number unavailable. Here the log on 3CX:
    16:23:59.179 [CM503008]: Call(73): Call is terminated
    16:23:59.179 [CM503015]: Call(73): Attempt to reach <sip:20001@10.23.10.200:5060> failed. Reason: Server Failure
    16:23:59.179 [CM503003]: Call(73): Call to sip:20001@10.24.10.102:5060 has failed; Cause: 503 Service Unavailable; warning: ; from IP:10.24.10.102:5060
    16:23:59.085 [CM503024]: Call(73): Calling VoIPline:20001@(Ln.19999@10.24.10.102)@[Dev:sip:19999@10.24.10.102:5060]
    16:23:59.069 [CM503004]: Call(73): Route 1: VoIPline:20001@(Ln.19999@10.24.10.102)@[Dev:sip:19999@10.24.10.102:5060]
    16:23:59.069 [CM503010]: Making route(s) to <sip:20001@10.23.10.200:5060>
    16:23:59.054 [CM503001]: Call(73): Incoming call from Ext.10001 to <sip:20001@10.23.10.200:5060>
    Any help or suggest ? Many thanks in advance
    Luigi
  2. bluetel2
    bluetel2 Member
    Oct 16, 2008
    377
    6
    hello,
    i suggest that your provider CCM is not configured. the provider icon is green ?
  3. lpietro
    Oct 28, 2009
    many thanks for the quick reply,
    Yes, in the port/trunk status i've the VoIP provider in the registered status ( green ). What I don't know is where to configure in the cisco callmanager the Virtual Extension Number ( 1999 ) I've configured with VoIP provider.
    I've seen that Callmanager is able to send call to 3CX phones , so it seems that 3CX is missing "something" ( is missing from my knowledge ) in authenticating to callmanager when the calls starts from his side.
    Any experience connecting to Cisco callmanager via SIP trunk ?
    Many thanks for the support and best regards
    Luigi
  4. TwigsUSAN
    Jan 31, 2007
    45
    What version of CCM are you trying to connect to. In my pass experience of trying to do SIP trunking to a CCM (not 3CX) it doesn't work so well. Cisco has been know not to follow the normal SIP protocols.
  5. lpietro
    Oct 28, 2009
    the callmanager I've is 7.1. But the strange behaviour is that the trunk is up because CCM-->3CX is working.
    Regards
    Luigi
