Calls with no voice
Discussion in '3CX Phone System - General' started by cow101, Jul 22, 2011.
  1. cow101
    Jun 23, 2011
    5
    Hello, I have a 2 locations and my "out of LAN" phones can call and connect but there is no voice, it is a firewall problem when I disable the firewall everthing works fine. I need to know what ports should I open.
  2. varietel
    Oct 29, 2010
    22
    Minimum
    ports 5060 TCP/UCP
    port 9000 - 9049 UDP
    Check the following blog site for all the ports
    http://www.3cx.com/blog/docs/ports-used/
    Roger Partovi
    Varietel Communications
    Certified 3CX Partner
    801-889-1414
  3. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
    Have you checked also 'PBX delivers audio' ON for these extensions ?
    The problem with audio could be peer-to-peer related.
    Regards.
  4. willow
    willow Member
    Mar 1, 2011
    471
    make sure that 9000 to 9049 (usually the defautes) UDP are open and not blocked.
