calltriggercmd.exe makecall stopped working
Discussion in 'Windows' started by adminbod, Sep 19, 2017.
  1. adminbod
    Jan 18, 2010
    36
    Hi -
    we have a simple 'click to dial' .net application that uses the makecall command via the calltriggercmd.exe.
    Its a button that sends the phone number over to the windows 3cx client and initiates the call.
    the makecall command has stopped working this morning - as in its not communicating with the local 3cx client
    not sure where to start looking for answers - are there any log files?
    cheers...
