CallTriggerCmd.exe only works first time
Discussion in '3CX Phone System - General' started by Jim400, Sep 20, 2015.
  1. Jim400
    Sep 20, 2015
    I am trying to use CallTriggerCmd.exe for outbound calls. This works correctly the first time I use it after the softphone is loaded.
    On second and subsequent calls, "Enter Number" appears instead of "On Hook", Line1 goes green, and the bottom "Call" button goes red with a phone symbol.
    If I restart the phone, it works first time again, but not thereafter.
    Any solutions?
    By the way, using version 12.5.44178.0
    Thanks, Jim.
  2. Jim400
    Sep 20, 2015
    No replies so far.
    Anyone have any ideas, solution?
    Thanks,
    Jim
