CallTriggerCmd prefix
Discussion in 'Windows' started by dxb, Apr 19, 2016.
  1. dxb
    dxb
    Feb 26, 2016
    Hi everybody,
    is it possible to add a prefix to a telephone number when I use the CallTriggerCmd ?
    We have set the 3cx to dial out using prefix 0.
    When we click a tel: link on website, the number dialed is without any prefix and we cannot place the call.
  2. dxb
    dxb
    Feb 26, 2016
    I tried to modify the registry key HKCR\3cxphone\shell\open\command\default
    from
    C:\ProgramData\3CXPhone for Windows\PhoneApp\CallTriggerCmd.exe -cmd makecall: "%1"
    to
    C:\ProgramData\3CXPhone for Windows\PhoneApp\CallTriggerCmd.exe -cmd makecall: "0%1"
    but instead calling the right number with an extra 0, it add as prefix "0835"
    with CallTriggerCmd.exe -cmd makecall: "1%1" > prefix will become "1835"
    Any idea ?
  3. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,340
    77
    This is happening because the tel protocol does not in fact send only the number, so the %1 variable does not contain e.g. 123456789, it contains the 'tel:' prefix as well, so the parameter %1 actually contains "tel:123456789", so I am assuming that the peculiar 835 numbers have something to do with the 'tel' characters in the parameter.
    I thought of something that might work, change the registry keys completely and point them to a bat file that will take the %1 as a parameter, then remove the 'tel:' characters and then invoke the CallTriggerCmd.exe with the modified number.
    The .bat file you create could look something like this:
    Code:
    @echo off
    set new_num=%1
    set new_num=%new_num:tel:=%
    "C:\ProgramData\3CXPhone for Windows\PhoneApp\3CXClickToCall.exe" --dial %new_num%
    So assuming the bat file is c:\call_trigger.bat, the the registry key would be something like:
    c:\call_trigger.bat "0%1"
    where 0 would be your prefix.
    I didn't test it extensively, but it should work.
