Can´t forward to outside number
Discussion in '3CX Phone System - General' started by HansO, Jun 17, 2013.
  1. HansO
    Jun 17, 2013
    5
    I'am pretty new to 3CX.
    I can´t foward an extension to an outside number.
    BR Hans
    10,563
    245
    You need to provide more information, such as the type of trunks you are using. You do have more that one trunk (one for the incoming call, and a second for the outgoing), correct?
    The 3CX log will show the reason it's not working. If you don't understand what it's telling you, then post a copy.
  3. HansO
    Jun 17, 2013
    5
    When I checked this out today it works perfectly and I could´t see any errors in the log file.
  4. leejor
    10,563
    245
    Well, needless to say, something wasn't working previously. You're not going to get an error message if all is working the way it should. If it begins failing again, then check the logs right away.
