Solved can’t establish a connection to the server at x.x.x.x
Discussion in '3CX Phone System - General' started by karomeh, Feb 28, 2018.
  1. karomeh
    Feb 28, 2018
    5
    I have installed 3cx couple weeks ago, and it's been working fine until last Monday when i lost access to the management console.
    the services are working fine, but I cannot get any access to modify and change anything, I do not want to uninstall and reinstall again, as all my researches ended up with that solution,
    3cx is installed locally on windows 10 Pro, version 1709, all Updated,
    3cx is latest version, 3CX Phone System Professional
    Firewall on windows pro all disabled, I have no Antivirus, and it's all used to work locally
    Any Ideas?
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,016
    421
    Hello @karomeh
    Do you get an error when trying to login? Are all services up and running?
  3. karomeh
    Feb 28, 2018
    5
    yes I get the error when I try to open the support portal, the services are up and running
  4. YiannisH_3CX
    May 10, 2016
    6,016
    421
    Can you provide a screenshot of the error so we ca have a better understanding of the issue? Hide any sensitive info the screenshot might contain.
  5. karomeh
    Feb 28, 2018
    5
    here is the error, i've tried more than one browser, same error happening
      File size:
      86.4 KB
  6. YiannisH_3CX
    May 10, 2016
    6,016
    421
    Try to access the server with the local IP and port 5000 from the local network and see if that works. It looks like port 5001 is closed on the firewall.
    e.g. http://<local_IP>:5000
  7. karomeh
    Feb 28, 2018
    5
    I've tried that, same problem.
    and i don't have any firewalls on, it was working week ago
  8. YiannisH_3CX
    May 10, 2016
    6,016
    421
    Have you tried accessing it from the actual server 3CX is installed on? Do you get the same error?
  9. karomeh
    Feb 28, 2018
    5
    yes, I only access it from the server it self. the error still there
  10. YiannisH_3CX
    May 10, 2016
    6,016
    421
    Please check your inbox as i have sent you a p.m. regarding what we will need to further troubleshoot your issue.
  11. YiannisH_3CX
    May 10, 2016
    6,016
    421
    The issue was that the management console and Nginx service were not running on the server. Once we started the services the management console was again available.
