Can’t install v10 Desktop Components due to error
Discussion in '3CX Phone System - General' started by rmm, Oct 8, 2011.
  1. rmm
    rmm
    Aug 27, 2009
    23
    Hello. Just upgraded from v9 to v10 (and moved to a dedicated 3CX server – 2008 R2) and am having this consistent issue putting MyPhone on first desktop (my Vista laptop):
    Run the exe.
    First error is that there is not enough disc space to uncompress and install prerequisite software (not true).
    Second error is that .NET4 prerequisite was not correctly installed 4154. But I have .NET4 in and up-to-date. But given issue 1 I could accept.
    Third error is I don’t have sufficient privileges, so log on as Administrator (again, not true – I am Administrator of this computer).
    Any ideas gratefully received. Thank you.
  2. rmm
    rmm
    Aug 27, 2009
    23
    Update on this: for sure it’s a Vista OS issue – I’ve had failed (as described above) installs on two Vista OS clients, while having two perfect installs on Windows 7 OS clients.
    If anyone has any pointers that’d be great as we use Assistant (now MyPhone) to indicate incoming queues and as of this weekend’s upgrade from v9 to v10, we’re in a bit of state to say the least due to this unforeseen consequence.
    Thank you.
  3. davidbenwell
    davidbenwell Active Member
    Apr 27, 2010
    704
    install .NET 3.5 and try installing Desktop Components again.
  4. rmm
    rmm
    Aug 27, 2009
    23
    Thanks Dave, but both the Vista machines in question already have .Net 3.5 SP1 on there for another business app. we use.
